"Pink Spring" ?
Old Jun 12, 2003 | 10:19 AM
DuckRyder's Avatar
DuckRyder
"Pink Spring" ?
The Book "Ford Performance" reccomends a "pink" relif spring in the oil pump.
Any one know of a source / part number for it?
I know we used to shim them in small block chevy's will that work? if so how much? 1mm?
Old Jun 13, 2003 | 12:33 AM
baddad457's Avatar
baddad457
"Pink Spring" ?
Try Blue Thunder.com for a Pink spring. Or just shim it. Or just do what I did, just go buy a high pressure oil pump, either way you'll accomplish what you want. I overhauled a 59,000 mile 390 in a 68 Merc , just replaced the bearings on the crank ( no turning neccessary) and with the HP pump it's got 70psi hot with 20-50 oil
reamer
18
Oct 10, 2014 01:00 PM
351Cleveland C4
16
Aug 26, 2014 10:01 AM
53flathead
15
Oct 29, 2008 07:01 PM
1WOO
1947 and Older Ford Trucks
Jun 23, 2007 12:00 AM
skidooman
Nov 24, 2006 10:26 PM
