Rob's New build
I bought them both Friday, because it seemed like a good deal - 900 isn't that bad for just the turbo, if it's in good shape(I think).
Anyway, I checked it out, and the turbo seems perfect - no end play, turns smoothly and things were surprisingly not rusted that badly(I'm guessing the turbo wasn't on that long).
My original plan called for putting this turbo on my '88 F250, but I've been thinking about just building up this '93 motor, and dropping the whole thing in my truck.
Here's some pictures:
Offloading: Link
Turbo side: Link
Block, mounted on a heavy duty engine stand. Top of the engine has been stripped:
Link
Parts layed out:
Link
Turbo:
Link
Lifters, all labeled
Link
Now, here's some closeups of a couple of the lifters. Note the wear:
Link
Link
Can this tell me anything?
A couple of the lifters have a bit of wear at that spot - down a couple of thou at least, if not .005+. Some have those markings, but aren't more than a couple of tenths(.0001).
Is this normal wear and tear, or should I get in and deburr the edges of the oil journels where that wear would come from?
Also, the cyl walls look pretty darn smooth, no noticable crosshatch that I can see. I'm wondering what I should be looking for, wear wise, and what I should replace while the engine is apart.
I'm already planning on getting the cam ground to better take advantage of the turbo - probably a Typ4 grind, to help with torque at the low end(where the turbo isn't as useful), but I don't know enough yet.
I haven't taken the oil pan off, but it does rotate smoothly - when I first found the engine, it had a "sticky" spot when turning it over, which turned out to be a little rust on the side of one of the cyl walls(likely due to sitting for three years or so). Cleaned it with scotch-brite, and it seems to be OK.
Any hints/stuff to check guys?
-Rob
If you have the engine tore down, haul it in and have the block mic'd or mic it yourself if you can. That will tell you if the cylinders are good, or need cleaned up.
When using a micrometer to check the cyls, am I just checking for out-of-round(I recall something about that in the book), or something else?
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&current=dynocams.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/dynocams.jpg" border="0" alt="Photobucket"></a>
that's Russ' grind kicking tail and taking names off the line.
iv often said it,but it's been awhile so what the heck.if i ever have to pull my engine,she wouldn't go back in without the torque cam.sure others may look cool and peak higher,but the grind from Russ puts the nuts right where you want it for 99% street/tow use imho.
Also, are the red lines from a stock NA engine, turbo with stock cam, or what?
My understanding of the torque cam vs stage 1 goes as thus: The stage 1 is pretty close to the torque cam on the exhaust lobe. The stage one has a better LSA and more lift on the intake lobe, the torque cam is stock intake. The LSA helps to drop reversion (exhaust gas being forced back into the combustion chamber while both valves are open), which is a problem with the stock cam and forced induction. The LSA on the stage 1 helps cut down on that, however as a byproduct slightly drops dynamic compression ratio. Given that our engines have such high compression, that isnt a problem for me.
To sum it up, i think a cam comparison between the two in the same engine the stage 1 would have the same low end as the torque cam while beating it in midrange and really pulling on the top end. All while building less boost, cooler intake temps and cooler egts.
Thats what i think, whether im right or wrong is hard to say.
Typ4/ 1991 F350 5-spd/(218/461@14psi)/60-1 wheel,CAI,typ4 cam, IC'd
91dirtydiesel/ 1991 F350 5-spd/(202/419@17psi)/ATS turbo,Intake tube & filter,5" exhaust
https://www.ford-trucks.com/forums/1...no-day-v1.html
looks like it.he hasn't been on a dyno with the new cam yet? when did he switch?
it would be cool to see a couple diff cams in the same exact engine (with one of the big 3 turbo's just because it would help the masses - well turbo idi's are already in the minority as is,but the masses for those who do anyway) but like you say.....not likely lol.
I'm quite interested in what I can do around the 1200-1600RPM range for good efficiency and power; right now I can't climb a relatively steep hill unloaded in high gear at 60mph/1600(I slowly lose speed). I'm guessing that with this turbo and a good cam, I should be able to cruise up it at that, and downshift if I need to do some accelerating.
