Distributor Gear Identification
Old Oct 24, 2005 | 10:54 AM
lmadore's Avatar
lmadore
I've got an 86 5.0 EFI. I'm not positive, but the engine may not be an original. The distributor is shot and I need to buy a replacement.
Every parts store that I have talked to says they need to know if it is a steel gear or a cast iron gear on the distributor. I can't very well remove the distributor to check. This is a daily driver and I need to keep the downtime to a minimum.
From what I have researched thus far, the type of gear depends on the type of cam (I.E. Roller Cam vs. others). MSD distributor uses a steel gear for a roller cam, cast iron for other.
Is there anyway that I can identify the type of distributor gear based on the motor (year/application) or an identifying feature on the exposed part of the distributor.
If I had to guess right now I would say 86-93 has a steel gear and 94-95 uses a cast iron gear based on information I found on the MSD Ignition website. I was looking at the Pro-Billet distributors. Actually I'll probably be going with a Stock Distributor when I replace this thing.
Any help would be appreciated.
Old Oct 24, 2005 | 12:42 PM
Blurry94's Avatar
Blurry94
Roller cam gets a steel gear, and flat tappet cam gets a cast gear
Old Oct 25, 2005 | 07:53 AM
lmadore's Avatar
lmadore
Blurry94
Good Call. It is a cast iron gear.
Finally found someone locally who new more about it as well. Mustangs got the roller cam that early, but not the trucks.
1951flatheaddave
22
Oct 18, 2017 09:41 AM
gxsalas
Dec 13, 2015 12:46 PM
1979 300i6
Feb 3, 2014 01:15 AM
medino03
Sep 7, 2012 10:16 AM
piperig78
Mar 29, 2011 09:34 PM
