Tech Question
Old Jul 17, 2013 | 09:23 AM
ManchuWarrior19's Avatar
ManchuWarrior19
Tech Question
So I bought a 92 F150 with the 4.9 6 cyl. It only has 109,000 on it and was running really good. I did a tune up, new motorcraft plugs, new wires, and put in a new egr valve put didn't put in a new valve position sensor. Well when driving down the road my check engine light is flashing on then ill accelerate and then will flash off. It does not stay on. It starts just fine, idles good, just when your driving it will flash on and off. Any ideas out there?
Old Jul 17, 2013 | 10:08 AM
Bob Gervais's Avatar
Bob Gervais
The best thing you can do to help yourself out is to pull the codes. Even if the light isn't on currently, any codes that were set will be stored.
Fuel Injection Technical Library » How To Run a Self-Test
Fuel Injection Technical Library » 3 Digit Self-test Codes 111-171
gtown_will
Jul 27, 2012 08:32 PM
Kenneth Sides
Oct 18, 2011 06:44 PM
madcapper
3.8 & 4.2L V6
15
May 8, 2008 07:55 PM
Dalamatition
Jun 12, 2005 08:53 PM
Schlump
1978 - 1996 Big Bronco
Oct 3, 2003 05:48 PM
