Excursion Virgin
Old Jul 29, 2013 | 12:03 PM
  #46
LivingLarge's Avatar
LivingLarge
Nice work, looks great!
Old Jul 29, 2013 | 03:10 PM
  #47
HokieHiVPI's Avatar
HokieHiVPI
Damn, you boys don't play around! I expected this to be a few months. You're damn near done! Which procomps did you go with? Looks awesome.
Old Jul 29, 2013 | 06:14 PM
  #48
sammie0126's Avatar
sammie0126
Well it does look nice even in White.
Old Jul 29, 2013 | 06:27 PM
  #49
HokieHiVPI's Avatar
HokieHiVPI
Pssst, your jealousy is showing.
Old Jul 29, 2013 | 07:50 PM
  #50
jayjjcc's Avatar
jayjjcc
I agree with hokie I didn't even see this thread start and the project is done... looks good!
Old Jul 30, 2013 | 07:46 PM
  #51
Jud x's Avatar
Jud x
Front Springs Pro Comp Lifted Leaf Springs 22410
Rear Springs Pro Comp Lifted Leaf Springs 22415
Thank you "~Christina" for those part numbers.
Old Jul 30, 2013 | 08:36 PM
  #52
Jud x's Avatar
Jud x
Had a couple more things show up on the big brown truck. So out to the shop. Started by removing the air cleaner box which was damaged in the accident. I left the front part which wraps around the battery and used a die grinder to do some trimming. removing tabs and such for a smooth box side.
Then I installed the filter kit from Riffraff. Let her breath.
Old Aug 1, 2013 | 12:02 AM
  #53
Jud x's Avatar
Jud x
Might have to put the UPS driver on my Xmas list after this project. He dropped off the new adjustable track bar from Zone Offroad Products.
Installed and took her for a little spin. To the alignment shop tomorrow and hopefully to my driveway tomorrow night.
Old Aug 3, 2013 | 06:33 PM
  #54
Jud x's Avatar
Jud x
Alignment is done and the X is home.
Old Aug 7, 2013 | 02:59 PM
  #55
gabeyd's Avatar
gabeyd
That should be 22210 in the front right?
Couple of other questions:
- What wheels and tires and what size are those?
- Did you do any block or shim at all under the 22415 in the rear? How's the drive angle?
- No pitman arm, or drop bracket? Just the adjustable track bar? Can you take a picture of the angle that those sit at now, from the front of the truck.
- No re-location for the sway bar (or bars if you have them in the back)?
- The rear 22415 sprints list as fitting a 2x4 (RWD) truck only, but it seems all of you are putting them on the 4x4 with no block right?
Thanks, I'm thinking of doing Procomp 22210/22415 also...
Old Aug 8, 2013 | 08:35 AM
  #56
Turfzilla's Avatar
Turfzilla
What color is it going to end up being? Please tell me it's not going to be white?
Whats wrong with white? Its one of the only two vehicle color I would ever buy, black being the other.
BTW: Jud that turned out great!! Like it very much.
Old Aug 8, 2013 | 06:30 PM
  #57
Jud x's Avatar
Jud x
Yes.. Pro Comp 22210 in the front.
Stock rims? ( on it when I got it) and Cooper 285's
No shim for now. I am sitting 42.5 front and 43" rear to the fender well. I am going to see what comes of the stance. A little more weight with the 7.3 up front. After I put $148 of diesel in today, I haven't done a measurement or with the boat. I had Ubolt's made a local spring shop with the ability to add a 1" block back in. I did take the 2+" block out.
Adjustable track bar only so far. No vibrations.
Rides awsome. My buddies can't believe how nice it rides after the new suspension and shocks.
I'll try to post a pic up this weekend.. I don't feel like laying in water to take a picture since its raining.
Old Aug 8, 2013 | 06:32 PM
  #58
Jud x's Avatar
Jud x
Thanks Turf.
Old Aug 20, 2013 | 07:50 PM
  #59
Jud x's Avatar
Jud x
Had some time this weekend to finish up a couple more things on the X. First started by taking out the old deck/CD changer and trading a guy at work for a set of '08 hub caps.
Old Aug 20, 2013 | 07:52 PM
  #60
Jud x's Avatar
Jud x
Got the new deck, amp and sub installed.
