Engine Removal Questions
Old Jul 17, 2013 | 09:40 PM
ReBilld's Avatar
ReBilld
Originally Posted by OldWoodsDiesel
Bill - would you guess its easier out the top with the I-beam above? I just built a storage loft in my barn and headed the joists off with a 14" tall laminated beam rated for something ridiculous amount of load - with the expressed intent of yanking engines with it. plan would be to remove the hood, position the truck under the beam, and pull it out with the chain-fall.
getting in lined up on the way back in would be tricky, though as I would only have forward/reverse adjustment by moving the truck. I figure a set of wheel dollys would solve that problem though...
If you have the height then that would be easier than pulling the core support. If it's a manual trans, you should drop the trans out and remove the clutch and pressure plate before trying to pull it out the top. I need to clear the parts out of my shop so I can use the beam again.
jgavac
18
Mar 8, 2016 04:07 PM
I-6 Power
Nov 25, 2013 08:57 PM
LongRider
Jul 24, 2013 08:04 AM
john11139
May 10, 2011 01:26 PM
cutlass
Apr 24, 2011 03:12 AM
