Knock sensor question on engine swap..
Old Jul 11, 2002 | 11:31 PM
brett_d's Avatar
brett_d
I am still in the process of swaping my engines and I noticed on my new block that it does not have the hole drilled in the back for the knock sensor. Is there going to be any problems with just disconnecting it?
Old Jul 12, 2002 | 06:58 AM
Gates's Avatar
Gates
I recently (last year) did a swap from a 1991 302 with 5 speed to a 1982 block with a C6. I ran into the same problem and I just did not worry about the knock sensor and left it unplugged.
The sensor is used to retard your timing if a knock is sensed. You'll have to make sure you get you timing set 100% but other then that it will not effect anything.
Corey
Old Jul 13, 2002 | 05:43 AM
brett_d's Avatar
brett_d
Thanks for the info. I figured that would be the end result. Did the computer throw out error codes after you disconnected it?
Old Jul 13, 2002 | 09:49 AM
ftrain's Avatar
ftrain
daddylee100
Mar 10, 2015 06:42 PM
trvctyrich
Dec 9, 2011 03:03 PM
Supercab
Mar 6, 2006 09:05 AM
Supercab
Nov 6, 2004 03:48 PM
Hanky
Electrical Systems/Wiring
Feb 10, 2001 12:49 PM
