Traction help
Old Jul 15, 2013 | 01:31 PM
beartracks's Avatar
beartracks
Traction help
I seriously need some traction help. (Lost my last post)
At one time I used "Suretrac" bars that are a single bar on top of the leaf spring mount. They did kind of work but I think they got bound up a bit.
Ladder bars or a 4 link can get kind of complicated by the time you float the axle.
Don't want to ruin the ride or the ability to carry anything. Guess I don't want much huh? LOL.
Tell me about your 1/4 mile times and traction devices.
Beartracks
Old Jul 15, 2013 | 01:38 PM
HIO Silver's Avatar
HIO Silver
Is your traction issue wheel hop or a lack of weight over the rear tires? For the former, I suggest a torque arm. For the latter, there's a water bag intended for traction in snow.
Maybe both.
Old Jul 15, 2013 | 05:15 PM
MikePacey's Avatar
MikePacey
Are you running a radial or a slick?
Old Jul 15, 2013 | 06:00 PM
AK FORD GUY's Avatar
AK FORD GUY
From the picture in his gallery, it looks like he's running BF Goodrich Radial T'A's.
Old Jul 15, 2013 | 07:21 PM
hp246's Avatar
hp246
I'm using a set of cal Tracs and Mickey Thompson tires. Calvert Racing - The Leader in Leaf Spring Innovation
Its just a street rod, so I can't give you and track data.
Old Jul 16, 2013 | 12:46 PM
rogue40's Avatar
rogue40
I've stripped out torque arms that were set up poorly and replaced them with good old fashioned traction bars. Once you get your pinion lead angle set it is a simple matter to fabricate the traction bars exactly where you need them with zero binding for the leafs.
Proper slack positioning is vital for any traction device.
Old Jul 16, 2013 | 05:51 PM
Fordboy88's Avatar
Fordboy88
x2 for caltracs. They still give a good ride on the street and great at the track.
Old Jul 19, 2013 | 01:40 PM
beartracks's Avatar
beartracks
Sorry I haven't got back. The wife thinks I don't have anything to do! I don't have any wheel hop and I dont think the springs wrap up. I have air bags which ad clamps to the springs and another clamp front and back.
Looks like I'll take the air bags off and go back to the "SureTrac" bars. Don't know if they are still made but similar to Caltrac. You have to make your own front mount.
Yes I['m running BFG's. Time for new ones. Might switch to Nitto's. Any advice there?
Also, I need to go to shorter shocks since I'm lowered. Any experience with air shocks such as the old HiJackers? It's a shock and air bag in one. That would make up for losing my air bags but I don't know if it'll compensate for the shorter length mounting distance.
Thanks
Old Jul 19, 2013 | 02:23 PM
Sooper Camper's Avatar
Sooper Camper
i built these for my old bronco wheeler. did wonders for the handling, improved sway, way better traction, before i could not put any power down going through sandy whoop-de-doos at speed. afterwards, i was keeping up with 4-linked vehicles pretty easily.
i don't have very good pictures, but the rear cycled ~15" of travel and there was no binding. it jumped pretty good with that setup too, much more controlled upon landing.
Old Jul 19, 2013 | 02:24 PM
Sooper Camper
think of it less and less as a leaf spring setup, and more like a parallel 4-link but with a slightly variable upper link. when i did full droop to full compression tests, the spring eye moved no more than about 1/2" through 15" of travel.
beartracks
Jul 5, 2013 11:26 PM
1992FordF150Custom
22
Sep 23, 2012 11:52 PM
jmm
Mar 8, 2008 07:41 PM
Knucklebuster
19
Dec 31, 2003 10:38 AM
OdinVII
Aug 18, 2003 04:02 PM
