Sponsored by: Kumho
traction bars
Old Aug 4, 2003 | 10:24 PM
OdinVII's Avatar
OdinVII
traction bars
Is there any negative effect(s) that traction bars will have on my ride in normal, everyday driving? I know they increase traction, and traction is never a bad thing, but my dad tells me I won't be able to take the corners very well if I put 'em on.
Any help is appreciated.
Old Aug 17, 2003 | 10:15 PM
pinellas50's Avatar
pinellas50
traction bars
Traction bars will not effect handling at all and will not have any negative effects on your leaf spring rear. The only problem folks sometimes have is clearance between the bars and the road. I don't imagine this will be much of a concern on your truck.
Old Aug 18, 2003 | 01:01 AM
mrwizard's Avatar
mrwizard
traction bars
Traction bars don't improve traction, they help to eliminate or minimize wheel hop. The only ways to actually improve "traction" are bigger/softer tires or more downforce on the tires.
Old Aug 18, 2003 | 01:33 AM
pinellas50's Avatar
pinellas50
traction bars
I'll have to respectfully disagree.
When tuned correctly, the traction bars control the pinion angle and also transfer the force of the rearend twisting into lift on the frame ahead of the rear.
Pinion angle has alot to do with the vehicles ability to place its weight onto the rear tires in order to gain traction. This is why many dedicated race cars use ladder bars or a four link system. The transfer of weight to the rear tires is just as important.
The main problem you have OdinVII is inherent to most any truck and that is the majority of the wieght is on the nose. Traction bars may help but don't expect a night and day difference. Moving some weight to the rear of the truck will be just as beneficial.
Tricks such as adding ballast(ie. weight) to the rear bumper or furtherst point rear on the frame is an option. Moving things like fuel tanks and batteries back there is another. Of course, these options aren't usually very feasible or practical on a daily driver.
Old Aug 18, 2003 | 08:00 AM
StrangeRanger's Avatar
StrangeRanger
traction bars
Also, there's the minor problem of slapper-type traction bars not being compatible with a spring-over axle. You need the parallel-link (i.e. Shelby-style) bars or the long off-road bars. Another option woulb be the Cal-trax or similar.
Old Aug 18, 2003 | 10:00 AM
Overkill's Avatar
Overkill
FTE *******
traction bars
OdinVII,
IMO, the bigger issue with most traction bars is that if not properly engineered they will limit suspension travel. Traction bars operate in an arch which must match the defection rate of the springs. If not a bind will result. This may be overcome by the use of telescopic bars but again, these must be properly engineered for the specific application.
A related discussion of this principal can be found here: Monster Tech
Hope this helps.
Old Aug 18, 2003 | 04:00 PM
OdinVII's Avatar
OdinVII
traction bars
Thank you all for your help. I greatly appreciate it all.
Old Aug 18, 2003 | 04:02 PM
OdinVII's Avatar
OdinVII
traction bars
Could you tell me why this won't be feasible on a daily driver?
Thanks in advance.
