Sponsored by: Real Truck
Changing Gears
Old Jul 15, 2013 | 10:09 AM
SuperWoman77's Avatar
SuperWoman77
Changing Gears
Ok, because of your guys' help, I am now going to get the gears changed instead of purchasing a chip/tuner. Now, I need help with input from all of you lovely people with what gears would be best.
The truck is a 2000 F250 5.4 (gas). It has like 116k on it, 35" tires, and is a 5 speed.
I have seen a lot of people saying that they went with the 4.56, but then another guy said that the 4.88 would be better because of the size of the tires. We don't pull loads a lot. Probably like 6 times a year.
What is your opinion on gears? Is the gas mileage going to be cut drastically? Thanks again for all of your help!!!
Old Jul 15, 2013 | 05:10 PM
cartmanea's Avatar
cartmanea
What speed do you like to run on the highway?
IMO, the 5.4L should have 4.10 or 4.30 gears stock, so upgrade to 35s and that changes the need to 4.56-4.88s. I'd probably go with the 4.88s unless you like to run over 70-75. They'll give you the most noticeable improvement and will help your in-town mileage. If you spend a lot of time on the highway over 70, then go with 4.56s.
Old Jul 15, 2013 | 05:48 PM
redford's Avatar
redford
FTE Leadership Emeritus
OK, we can figure this out with the automotive calculators available on this site:
Automotive Calculators offer to you by Ford Trucks Enthusiasts | www.ford-trucks.com
Assuming you started with 32 inch tires and 3.73:1 gears, putting 35 inch tires on the truck reduced your effective drive ratio to 3.41:1. To just restore your truck to the effective stock ratio, you need 4.07:1 (4.10 would be the closest gear).
4.30 is the most recommended ratio for towing with a gas engine. To get an effective ratio of 4.30:1 with the 35 inch tires you would need a 4.70:1 gear set. 4.56 or 4.88 are your closest choices, so 4.88 is not that outrageous.
Old Jul 15, 2013 | 06:09 PM
KenRebF-250's Avatar
KenRebF-250
If you only tow occasionally I'd suggest the 4.56 ratio with the tall tires. If you were going to heavy tow quite a bit I'd say go with the 4.88 ratio.
With my stock tires (31.5" tall) and 4.30's what is my effective ratio. I'm a little dense and can't figure out how to do the calculation on the link.
There are a few times when I wish I had went with the 4.56 but those times are so infrequent as to be nearly non-existent. When I'm towing heavy into a stout wind, maybe, but the 5.4 still does just fine and that situation doesn't present itself very often at all.
Old Jul 15, 2013 | 07:09 PM
WE3ZS's Avatar
WE3ZS
When you do pull with it what kind of weight and profile are you hauling and for how long? 6 trips of 1200 miles with a 10k travel trailer would be a lot different than 6 pulls with a utility trailer with a couple of quads on it down to the local sand pit. If your tows are heavy with a high profile over any kind of distance then the 4.88's might be the better choice. If the pulls aren't so heavy or tall then the 4.56's will be a good choice and give a little better highway MPGs for daily use.
You are OK Ken, your effective ratio is 4.30 because your tire size is stock. The term effective ratio refers to the calculated ratio due to a tire size change, I went with 4.88's from my stock 3.73's becuse I wanted to be around 4.30 for towing, I am eventually getting 35" vs the stock 31.5" tires so then with the 4.88's my effective ratio will be 4.39.
Old Jul 16, 2013 | 01:12 AM
KenRebF-250
Thanks for the clarification WE3ZS.
Good advise in reference to weight and profile. Profile means a lot. The only time I pine for a 4.56 is when I'm bucking a strong wind pulling the camper.
Old Jul 16, 2013 | 10:00 AM
BigBlue99's Avatar
BigBlue99
I have about the same set up but with an automatic and I pull light loads (<10,000lbs) about twice to three times a month. I went with 4.56s and love them. I was recomended 4.88s but I cruise at 2500rpms 75mph now and I cant see wanting to turn any more revs than that at that cruise speed. 80-85mph is almost out of the question with any head wind. That 5.4 seems to be just making noise in OD at 3000rpm or so.
Old Jul 16, 2013 | 01:34 PM
caprisecca's Avatar
caprisecca
i am actually considering this very same thing. like the op i have the 01 5.4 with the 5speed, and 35 inch tires. now fuel mileage isnt a concern of mine but can anyone who has this set up tell me what kind of mpg to expect from the 4.88's.... i know i know it depends on drive style. but i have been averageing a very consistent 12.5 to 13.5 mixed driveing since ive started keeping track in january. oh thats with my factory 4.10s.
Old Jul 16, 2013 | 03:27 PM
BigBlue99's Avatar
BigBlue99
I get 10-11 consistantly with 4.56s regardless of which tune I use. I would not expect 4.88s to be much worse. The thing I looked at when deciding gear ratio was calculating the cruise rpm taking into account the tire size, rear ratio, and top gear ratio. For me I decided 4.56s because that put my truck cruising at 75mph at about 2500rpms which is about the peak torque for the 5.4.
Old Jul 16, 2013 | 05:21 PM
KenRebF-250
BigBlue, the 3 valve 5.4 must be quite a different animal from the 2 valve engine in reference to torque development. The torque really comes on strong at around 2200 rpm and sticks with you all the way past 4000 rpm.
The engine sounds as if it really likes pulling at 3000 rpm. I've never been around a 2 valve 5.4 so I have nothing to compare to.
Old Jul 16, 2013 | 05:27 PM
redford's Avatar
redford
The 5.4L 3V variable valve timing produces a lot more torque just off idle, compared to the 1999-2004 2V 5.4L engines.
Old Jul 16, 2013 | 08:14 PM
BigBlue99's Avatar
BigBlue99
Yeah the torque does come on good around 2200 but for me i wanted peak torque at my highest expected cruise speed in case i wanted to tow at that speed. The torque curve i have seen for the 5.4 in a SD peaks around 2500 and then flattens out after that. I have not seen my trucks curve just one i had seen online for a stock 5.4 2v
dewalters8886
Feb 17, 2017 10:29 AM
stumpbuster
Dec 29, 2012 01:16 PM
frdf250
24
Dec 29, 2009 11:43 AM
rednekrebel28
1997 - 2003 F150
Mar 10, 2008 05:24 PM
froman23
Feb 7, 2002 11:31 PM
