Rough Idle
Old Jul 14, 2013 | 09:31 PM
1991 F Super Duty's Avatar
1991 F Super Duty
Rough Idle
I had borrowed the IP off my 1991 and put it on my 1990 to determine if the other trucks IP was bad. I was going to leave it on my 1990 but it has bigger issues and will probably be pulling a head, as I had compression coming out of #7 injector back into the IP. I found it when I was bleeding injector lines, every compression stroke you could hear it pusing out the injector.
I reinstalled the good IP back into the 1991, I never should've touched it to begin with as it was running just fine before I removed it. Since reinstalling it, I have plagued with a rough idle, and sounds kinda power stroke or clacky. It really starts to ckack at highway speeds.
The IP was new a year ago and may have 50K on it
Here is what I have done to try to fix it;
installed 8 new injectors with Viton orings,
replaced the return lines,
rough adjusted the timing to about 1 deg Past TDC (yes towards the passenger side).
Even tried advancing the timing, to try to cure it.
checked the IP timing gear to make sure I am not off, and I am not!!!
I have gone over every inch of the hard fuel lines and the return lines looking for an air leak.
Listened to every injector with a mechanics stethoscope, thinking I may have a bad injector. I know even a new injector can be bad, if there is a bad one I seriously do not know what I am listening to.
With all that throw the ideas at me, what have I missed?
Old Jul 15, 2013 | 12:50 PM
RA31925's Avatar
RA31925
It sounds like your cold advance might be stuck on.
Old Jul 15, 2013 | 01:31 PM
1991 F Super Duty
I don't think it is the cold advance; when I cold start the truck, it will idle up for a few minutes and then kick back down to normal. I am just trying to Trouble Shoot the rough idle.
FordTruckfan89
Oct 20, 2014 09:42 PM
85grey
13
Sep 25, 2011 12:31 AM
91dirtydiesel
20
May 22, 2011 09:58 PM
jyblood
Dec 30, 2008 08:35 AM
polcat
Oct 3, 2008 09:12 PM
