Sponsored by: Real Truck
trans fluid change
Old Jun 11, 2003 | 11:04 PM
ford f250sd's Avatar
ford f250sd
Question trans fluid change
I know that this has probably been covered but I have to ask. I have a 1999 ford with a 4r100 trans and I want to change to synthetic fluid and I don't have any idea how? I know if i just empty the pan its only a small percent. So I would like to know how to change all 17 qts? Is it possible? and is it worth it to change to synthetic? Any help is appreciated.
1999 ford f-250 sd 4x4 auto 373 chipped k&n exhaust poweraide and 285s
Old Jun 11, 2003 | 11:41 PM
Outpost22's Avatar
Outpost22
trans fluid change
Read this:
https://www.ford-trucks.com/articles...hangingatf.php
Synthetic is great if you tow a lot. I just changed mine to regular Mercon as it wasn't worth it for me.
V10KLZZ71S's Avatar
V10KLZZ71S
trans fluid change
To me the best way to change fluid is to flush it with a flushing machine.It flushes your cooler and lines.It will be costly because of the amount of fluid used but it is the best way in my opinion.I flushed mine then dropped the pan and changed the filter, then refilled it.I believe the flushing instructions said changing the filter was unnecessery, but i did anyway. After we cut open the filter and it was clean.
mhatlen
Jul 12, 2012 02:37 AM
wanabe2
Jan 3, 2010 08:13 PM
JohnAW
Oil & Lubrication
76
Oct 26, 2008 04:16 PM
msmmce1
Mar 24, 2005 06:03 PM
IAAGGIE
Apr 3, 2004 08:31 AM
