shifter
Old Jul 11, 2013 | 12:07 PM
ppruitt's Avatar
ppruitt
shifter
My on the column shifter wont go into park 98 E150 5.4 liter
Old Jul 11, 2013 | 01:02 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There are a couple possibilities. There are two bolts on the steering column that hold the shift tube to the column. If they get loose or fall out this can happen. To check them lay under the driver's side dash looking up the column. The bolts have Torx heads. If they are missing or loose repair them as needed.
If that's fine the next thing to check is to see if a rock got lodged in the linkage. I've seen it happen on the trans where the shift cable attaches on the driver's side of the trans.
Old Jul 11, 2013 | 05:21 PM
ppruitt's Avatar
ppruitt
Thanks exactly what it was but a true pain to get to. Finally taped the torx scew to the torx and it worked perfectly.
hjartland
Feb 22, 2017 03:15 PM
Deedreamer
Dec 3, 2013 06:59 AM
add2255
Aug 28, 2010 12:02 PM
buffalobob
Dec 3, 2007 02:00 PM
DaveMac2Vans
Aerostar
Sep 27, 2006 12:12 PM
