77' F-350 Trans Fluid Question
Old 07-08-2013, 09:21 PM
old blue beast's Avatar
old blue beast
old blue beast is offline
Howdy Ya'll. Im doin the trans fluid on my 77' F-350. 460 W/ C6. I was wondering how I would drain the ENTIRE system of trans fluid. The trans is already drained. So I have to drain the Torque converter and the Trans Cooler, right? Its a Camper Special, so I presume it has a trans cooler. Anyones input?
Old 07-09-2013, 10:37 AM
Sooper Camper's Avatar
Sooper Camper
Sooper Camper is offline
find the lines feeding the trans cooler from the passenger side of the transmission, disconnect, drain into a bucket. they should at least go into the heat exchanger in the radiator, there might also be an air to fluid cooler behind the grille.
there are multiple ways to get the fluid out of the converter, most common would be to pull the flywheel inspection cover and rotate it until you can find a drain plug (if it has one).
Old 07-09-2013, 10:49 AM
AK FORD GUY's Avatar
AK FORD GUY
AK FORD GUY is offline
If the entire system is drained, is there any chance of damage upon start-up?
Old 07-09-2013, 12:37 PM
jas88's Avatar
jas88
jas88 is offline
Does your torque converter have a drain plug?
Old 07-09-2013, 01:04 PM
old blue beast
not sure yet, have to check...
Old 07-09-2013, 04:28 PM
old blue beast
Just to double check, the Torque Converter refills how if I were to drain it? Doesn't the fluid circulate threw the entire system?
Old 07-09-2013, 05:23 PM
V10man's Avatar
V10man
V10man is offline
Just did this to my truck. They do(should) have a tq converter drain plug. I dropped the pan, valve body(I did a shift kit). When the VB is off it drips fluid from everywhere! Then rotate the converter so the plug is down. Take it out and let her drain. I only had the radiator cooler so I didn't worry about that. You could use air to blow the lines if you wish. This should get most all the fluid out. Once it is buttoned back up put at least 6-8 qts in the tranny before starting it. It will pump it into the system and fill the converter. Mine took almost 12qts to fill.
Old 07-09-2013, 06:49 PM
old blue beast
Thankyou V10man, That's helpful
bigreentruck
06-11-2019 10:20 AM
ravens fan
11-05-2012 10:29 PM
dvskate
09-22-2011 07:44 PM
007sniper
06-21-2008 05:25 PM
Joe Finn
1997 - 2003 F150
01-29-2004 09:28 PM
Quick Reply: 77' F-350 Trans Fluid Question
