Trans problem
Old Sep 22, 2011 | 04:00 PM
dvskate's Avatar
dvskate
Trans problem
Put in my new built trans, torqued everything down, added some fluid and it won't take fluid or move the truck. Any ideas? I have a 2001 f250 4x4 automatic trans. It had a higher stall converter and suncoast internals. I'm stumped any help would be awesome.
Old Sep 22, 2011 | 07:05 PM
woodnthings's Avatar
woodnthings
How much fluid did it take initially? Did you cycle through each gear to purge air out of the transmission? When replacing a transmission, you really need to make sure it is "burped". Also did you add fluid to the converter before installing?
Old Sep 22, 2011 | 07:16 PM
dvskate's Avatar
dvskate
I ran through all gears with around 16 quarts in. Started to come out of the breather hose on top of the trans so I figured somthing was wrong. It has a bigger cooler so I figured it holds 19ish quarts. I was not told to fill the converter beforehand shouldn't it fill pretty quickly?
Old Sep 22, 2011 | 07:30 PM
nissandoc's Avatar
nissandoc
Stupid question but there is a filter in there right?
Old Sep 22, 2011 | 07:32 PM
dvskate's Avatar
dvskate
I hope they put it in
Old Sep 22, 2011 | 07:44 PM
nissandoc's Avatar
nissandoc
Reason I ask is because the filter goes directly into the pump and if it's not in there the pump doesn't get any fluid.
bigreentruck
Jun 11, 2019 10:20 AM
groggf250
Feb 13, 2010 03:44 PM
60RatRod
Mar 7, 2009 05:14 PM
ford390gashog
Apr 10, 2004 09:00 PM
