Transmission slips only sometimes?
Old Nov 4, 2012 | 08:12 PM
ravens fan's Avatar
ravens fan
Hi guys i have a 91 f150 with an E4od transmission when cold and just started up the transmission shifts smooth and fine through all gears but when warmed up it will a lot of times slip and go straight from 2nd to 4th gear
I realize this tranny is prob on its way out but is there any way of making it act a little better like a tranny cooler?
thanks
Old Nov 4, 2012 | 08:35 PM
Beechkid's Avatar
Beechkid
Time for a tranny service!
Old Nov 4, 2012 | 10:00 PM
ravens fan's Avatar
ravens fan
do you mean swap?
Old Nov 5, 2012 | 06:11 PM
Beechkid's Avatar
Beechkid
Originally Posted by ravens fan
do you mean swap?
remove the fluid & change the filter..
Here's what I have done on every vehicle (auto trans) that I have owned for 30 years....
At 20k miles, I change the filter (due to possible residual/initial wear particulates that may be floating inside) and either drain the torque converter (if so equipped with a plug) or disconnect the trans cooler line at the radiator, fill the pan with fresh fluid, my wife starts the engine and when 2-3 quarts drain into a bucket, she shuts it off, I refill the pan and repeat until the fluid is clear and in case of the f150, 14 quarts of fresh fluid is in.
I change only the fluid after that (unless I determine substances/contamination in the oil). The intervals vary depending on the type of trans, type of fluid and conditions, but in general, every 30k miles. Heat is a killer on automatic trans fluid and when we lived in the desert area, I changed the trans fluid at the end of summer every year.
In regards to filters, oem is fine, but I typically use Wix.
In regards to trans oil, both in sticks and autos I have always used Valvoline.
I have also never had a trans failure in any vehicle I own and typically keep my vehicles for 10+ years, with over 100k on the odometer.
Old Nov 5, 2012 | 10:29 PM
ravens fan's Avatar
ravens fan
thanks beechkid i will def have to do that soon
jawsfree
2004 - 2008 F150
Jul 17, 2013 12:23 PM
medic503
Jul 12, 2013 11:52 AM
Teager
Jan 10, 2013 07:09 PM
bchitwood73
1997 - 2003 F150
Aug 15, 2012 08:41 PM
chops0523
2004 - 2008 F150
Jun 4, 2010 03:25 PM
