po603 code
Old Jul 8, 2013 | 04:10 PM
alexisvfd's Avatar
alexisvfd
po603 code
I have a 04 6.0 and it just started today when I crank it it spins over for like 5 seconds before it cranks...runs fine just long crank any idea what this could be,,,
Old Jul 8, 2013 | 04:13 PM
alexisvfd's Avatar
alexisvfd
the code on my sct says internal control module keep alive
Old Jul 8, 2013 | 05:03 PM
alexisvfd's Avatar
alexisvfd
ive read with a programmer which I have it will pop up but I don't know about the long crank
Old Jul 8, 2013 | 05:27 PM
npccpartsman's Avatar
npccpartsman
It's a keep alive memory code that can pop up when you disconnect your batteries. You might want to check your battery cables to make sure you have a good connection. If you had a stored code it was erased.
As to the long crank. Was the motor hot or cold? Have you cleaned your EGR valve recently? Is it an 03 or 04 motor (ICP sensor on valve cover or under turbo)? Do you use OEM oil filters
Old Jul 8, 2013 | 05:58 PM
alexisvfd's Avatar
alexisvfd
the motor was hot and egr is deleted and turned off with my sct...it cranks fine now and its cold...what could cause it to do that while its hot
Old Jul 8, 2013 | 06:27 PM
mustang_309's Avatar
mustang_309
Likely a HPO leak. Depending if your ICP sensor is in the passenger valve cover or behind the turbo would determine what the possibilities would be, if it is in the passenger side valve cover it could be standpipes and dummy plugs, or a possible failing HPOP in either case. In this case it would be a good thing to do an air test of the HPO system.
Old Jul 8, 2013 | 06:33 PM
alexisvfd's Avatar
alexisvfd
icp is brand new so ill try the air test...whats the best way to do it
Old Jul 8, 2013 | 06:45 PM
mustang_309
Here is a youtube video showing an air test on an 04 6.0L,
Old Jul 8, 2013 | 08:55 PM
cheezit's Avatar
cheezit
p0603 is a kam code. its caused by a pcm reset
olyellow
Feb 4, 2019 06:22 PM
Stroker 6.0 fan
Oct 3, 2015 03:07 AM
krommag
May 23, 2010 07:39 PM
Jmatthews
Sep 9, 2008 06:37 PM
ksubuck
May 7, 2006 07:00 PM
