302 engine problems
Old Jul 9, 2013 | 11:22 AM
Greasemonkey93's Avatar
Greasemonkey93
egr solenoid has 47 ohms of resistance but does not change the engine idle when grounded. going to check the position sensor
Old Jul 9, 2013 | 11:24 AM
Greasemonkey93
the engine does die at idle if I take the heater control vac source and put it in place of the green egr vac line
Old Jul 9, 2013 | 11:48 AM
Greasemonkey93
the vac solenoid for the egr has 47 ohms resistance but does not affect the idle when grounded. the egr valve affects the idle if I use a different vac source(heater control vac line)
Old Jul 9, 2013 | 12:46 PM
jroehl's Avatar
jroehl
Okay, but you need to be checking voltages according to those links I posted. Also, you'll need a vacuum gauge/pump like this to test that the EGR valve is responding appropriately to vacuum:
Mityvac MV8000 Automotive Test and Bleeding Kit : Amazon.com : Automotive Mityvac MV8000 Automotive Test and Bleeding Kit : Amazon.com : Automotive
I'd offer to let you borrow mine, but that's a bit of a drive from your place to mine.
Jason
Old Jul 9, 2013 | 09:40 PM
Greasemonkey93
0% vac- about .52v and it steadily went from that to 3.87v. with 100%vac(12in) it was about 2.13v at 4 in. vac(which is the halfway point)
Old Jul 10, 2013 | 02:29 AM
RandR10's Avatar
RandR10
Check your coil too. Those will sometimes crack internally, and as the coil heats up, the crack expands and the coil loses continuity. In these cases, the only thing that allows the engine to start again is to let it cool enough for the expanded metal to shrink again.
Old Jul 10, 2013 | 08:02 AM
Greasemonkey93
the coil is one of many new parts installed that I was told would fix the stalling issue
Old Jul 10, 2013 | 10:18 PM
Greasemonkey93
have replaced: coil, plugs, wires, cap and rotor, icm, o2 sensor, vac lines, ignition assembly, all engine gaskets, pip sensor, as well as checked all wiring. have egr vac solenoid on order for tomorrow. have not looked at the eec though as its rusted t its bracket. the exhaust is not plugged as its currently free flowing with 2 glasspacks where the pre cat used to be. that's as much as I can think of at the moment.
Old Jul 13, 2013 | 01:10 PM
Greasemonkey93
well its still running like ****. smells of oil and cant keep running. sadly im thinkin its gonna end up needing rings :/ I knew I should've replaced them while the engine was apart. it only acts up after the engine warms up and I was told that the situation sounds like rings.
Old Jul 15, 2013 | 01:38 PM
Greasemonkey93
how do I check an inline fuel filter that might be plugged?
Old Jul 20, 2013 | 02:16 PM
RandR10's Avatar
RandR10
Take it off, put a clean and new piece of hose in the input end and blow through it. It should have no resistance at all after the liquid comes out. You can also put a fuel pressure tester on there, start it up and rev it to see if pressure drops a lot as the rpms go up.
In my experience though, plugged fuel filters haven't caused idle problems, but manifest when you go to accelerate and it needs the extra fuel. That doesn't mean it's not the problem, but it isn't the first place I'd look. Fuel filter is only like $2 though, so I'd just change it if it hasn't been done in a while. There's probably some rust in the tank due to all that sitting it did, especially if it wasn't full of fuel during that time. Moisture will collect in the head space and cause it to rust from the inside out. You might do well to change the fuel filter every few months until all that crap gets sucked out of the tank. Keep the tank full too so the rusting process is halted.
Old Jul 21, 2013 | 10:25 PM
Greasemonkey93
ok so i took the inline filter off and it was plugged solid. i took it to a friend of mine and he will be handling the tank and checking the in tank filter as well as testing the pump. i replaced both 10000 miles ago but i didnt replace or clean the tank. after thinking more the in tank filter may be clogged. the storm last night took out the tree behind my house so im gonne be busy for a few days.
Old Jul 22, 2013 | 09:50 PM
  #28
nflfreak43's Avatar
nflfreak43
Yes 92's and 93's with AOD's were the last trucks with 2 digit Obd-I codes.. Cause they're essentially using a 91 ecu..
Old Jul 22, 2013 | 10:33 PM
  #29
Lead Head's Avatar
Lead Head
Perform a leakdown and compression test if you think it is rings.
Old Jul 25, 2013 | 10:41 PM
  #30
Greasemonkey93
im not sure why my messages are not showing up. -_- anyways the diagnosis was that the pump wasnt making enough pressure or volume. 35 psi tops and less than 5oz after 3 key turns. replaced pump, sock and tank. old sock was so plugged that the pump and engine kept running dry. truck now drives alot better but on another note i lost 4 quarts of oil on a 15 mile ride and its not leaking externally. onl thing not replaced internally was the rings.
zach6050
Aug 27, 2016 09:59 PM
VADER2004
Nov 21, 2014 01:05 PM
bertha66
Aerostar
Nov 19, 2007 08:21 PM
OldRed4X4
Mar 29, 2007 09:20 AM
luke245
Dec 9, 2006 02:15 PM
