Bronco II Ford Bronco II
lean lean lean
Old Jul 7, 2013 | 10:54 PM
belchfire's Avatar
belchfire
lean lean lean
"85 w/ 2.8 & a4ld. wasn't running real happy but not too bad. Pulled trans & replaced converter seal & main seal. Fired it up & it won't idle. got it running long enough to try & warm it up & hit the brakes. Nasty groaning sound. Replaced brake booster but no change. No boost on brakes. substantial vacuum on oil filler inlet hose. Plugged booster hose-no change. Plugged pcv valve-no change. Modulator hose & new mod OK. What else should I be looking for?
Le Juggernaught
Aug 25, 2014 01:34 PM
1978Crew
Sep 23, 2010 09:37 AM
kenworthfan
1983 - 2012 Ranger & B-Series
Jul 31, 2007 05:31 PM
CheaperJeeper
16
Mar 11, 2007 12:00 AM
packrat56
Jan 24, 2005 05:41 PM
