Could be a vacuum leak. Is your brake booster hose connected to the carb or to the vacuum port on the intake? I would check the hose first to see there are no cracks/holes.
Drove with the vac hose to the brake booster disconnected and plugged.
The brakes still had to be pumped a couple of times before they would engage, but they did engage. Just like with the booster attached to vac, but harder to push the pedal.
Not seeing any difference in the idle with the booster disconnected.
If you have enough slack in the brake lines to unbolt the master cylinder and slide it forward some, try and see if the rear seal on the MC is leaking. The fluid didn't just disappear. Maybe the seal leaked and the booster took in the fluid, putting brake fluid into the combustion stream. Try idling it with a vacuum gauge connected to manifold vacuum, and see what the gauge says.
I would think it would draw from the rear portion of the res if the booster was bad?
If the front res was dry then you need to bleed the rear brakes to get the air bubble out of the line. Watch the res close cause it will run dry quick when bleeding the rear brakes.
Rear needed to be bled. After drilling the rust out of all four bleed screws, bled the system and the rear seemed to have all the air. Working fine now and did not have any connection to the rough idle problem.
