Bronco II Ford Bronco II
A question about a fuel pump issue...
Old Jul 10, 2013 | 12:22 AM
Andy1416's Avatar
Andy1416
Will the Fuel Pump, Hanger, and Sender Assembly from a 1988 Bronco II work in a 1989? The reason I ask is because I need a new fuel pump for my 1989 and a 1988 one is way cheaper.
Old Jul 10, 2013 | 01:45 PM
Josh S's Avatar
Josh S
I checked Autozone.com and sure enough they are different part numbers, although I can't imagine why. Will be interested to hear if anyone knows. Here's a picture of my '88 unit in the tank if it helps at all.
Old Jul 11, 2013 | 01:32 AM
97Centurion's Avatar
97Centurion
Rub my Belly
I believe the 88 fuel in tank pump has a lower PSI than the 89. The 88 uses two pumps. One in the tank and one on the frame rail. The fuel tank pump is a "feeder" pump for the higher pressure pump on the frame rail. The 89 uses a single high pressure pump (in the tank).
Doostien
Nov 16, 2014 06:20 AM
junglemike49
Feb 27, 2013 12:11 PM
skylarkman
1978 - 1996 Big Bronco
Dec 22, 2008 02:52 AM
fordmancounty
1983 - 2012 Ranger & B-Series
Jun 30, 2007 04:34 PM
amw_drizz
Bronco II
Jan 9, 2005 01:00 PM
