E350 ABS Light
Old Jul 1, 2020 | 07:48 AM
Carsten Olesen's Avatar
Carsten Olesen
Originally Posted by 94Sport5sp
Hi:
Short of taking the dash apart I have not located a black with red stripe trigger wire for the ABS light. The only wire I can find is part of the EEC TEST housing. There are three wires there. Two are wired to the housing and the third is an un-mated grey ended with an off white wire with a red stripe. I figured "What the ..." I may as well try ground on that wire. Well, I do not get any ABS flash codes but I did change the behavior of the ABS light. So progress in a way.
Up till now the ABS light was on solid. If I turned the key to the on position (without starting) the ABS light would remain on until I turned the key off. If I started the van then the ABS light would go off while the starter was engaged but come back on solid when the key returned to the on position. The ABS light would remain on until I turned the van off.
Now the ABS light comes on when I turn the key to the on position and remains on for about 3 seconds and then goes out. Looks like normal behavior. After about 25 seconds the ABS light comes back on and remains on until I turn the key off. The behavior is the same when I start the van. ABS light goes out while starter is engaged, remains out when key returns to on position and after about 25 seconds come back on solid and remains on until I turn the key off.
Grounding the un-mated grey ended wire from the EEC TEST connector does not cause the ABS light to flash. So is it the trigger wire and there are no codes to flash?
Looking for more ideas.
Thanks
Hi there. I have the same problem with my e350. Did you find a way to fix it ?
I can not see the date of this thread, is it old and inactive ?
Old Nov 8, 2023 | 07:11 PM
Sarahps33's Avatar
Sarahps33
Good God did you ever find it? I'm having the same issue, same year and model. Same random disconnected harnesses. I know this is from 2013 and I will probably never hear back, but hey it's worth a shot.
Old Jan 30, 2024 | 05:21 AM
wheelindude's Avatar
wheelindude
2nd Gear
On my 95 E350 the ABS code wire is by the battery on the left inner fender. Its black with an orange strip. My ABS light comes on at start up and goes out as normal. I drive about 50 feet and the light comes on with out applying the brake. Ground black and orange wire and no codes with key on, re drive light comes back on and test with out turning the key off, no codes. I have 1.5 volts at all sensor connections , 2500 ohms at all sensers , left the wheels off the ground and turn wheels the ohms fluctuate from 2500 to 2800 ohms showing the sensers and wheel rings are working properly. There is no 16 pin test connecter being it is pre 96. Can some one tell me what's next to find the problem. THanks
Old Jan 31, 2024 | 04:10 AM
manicmechanic007's Avatar
manicmechanic007
It takes a NGS and an adapter cable to plug in and read codes on that 95 you have
The pump run and prove out is not working
Initial startup and you start driving, you hit 7mph and the pump fires to charge the accumulator (that is what it is supposed to do)
If the ABS module (part of the HCU) does not see that pump run you get the light
Last one I fought for a year had a bag ground wire going to the HCU
The HCU had been replaced twice and they were ready to try a third
You need to read between the lines on those pinpoint tests as well
The motor in the HCU does not last forever
You need to have the codes pulled from the dealer or find someone in your area with a NGS
Old Jan 31, 2024 | 12:22 PM
wheelindude
2nd Gear
Thanks for the response, would that be G101, in front of the battery , I took it off and it was all green. buffed the wire ends and cleaned the bolt and nut. have not got a chance to test drive it. I see on the wire diagram G102 goes to the system also, there are two wires at this location, am I at the right spot. Thanks
tabijan
Oct 3, 2012 09:37 PM
wendal
Dec 18, 2009 02:12 PM
phantmlord
May 6, 2004 04:45 PM
brt
Aug 18, 2001 06:31 PM
