2004 explorer clicking noise
Old Jul 7, 2013 | 05:05 PM
edford1's Avatar
edford1
I have a 2004 explorer, 4.0 that has a clicking/rattling noise from the serpentine belt area. It sounds like it is coming from the belt tensioner. Is this how they sound if they are going bad?
Thanks,
edford1
Old Jul 7, 2013 | 10:54 PM
shorod's Avatar
shorod
As the bearings get REALLY worn they can start clicking/rattling. Usually before they get that bad though they start to make a tinny ringing noise at idle.
You can remove the serpentine belt and spin the various pulleys by hand to see if the tensioner is rough or loose, then confirm it's the only one. If all pulleys that spin freely (ie: not the power steering pump) are smooth, then you might want to start the engine and see if the clicking rattling noise is still present. If so, the issue is not with the belt-driven accessories but maybe an issue with the timing tensioners.
-Rod
Old Jul 8, 2013 | 06:13 PM
edford1's Avatar
edford1
-Rod
Thanks for the ideas !!!!!
98explorerguy
Jul 22, 2005 04:49 AM
Mr. Fixit
Apr 8, 2005 06:48 PM
pell
Jun 28, 2004 09:01 PM
Luis Hernandez
May 1, 2004 05:12 AM
surfer8400
1983 - 2012 Ranger & B-Series
Mar 19, 2004 09:56 AM
