Of note... The RV was designed for Canada, thus what looks like excessive speed for a 12,000 lb beast. Also, the check engine light was for the MAS. I cleaned that today and cleared the code.
I'll also add that when upshifting from 3-4, I'll sometimes get a small chirp/squeal out of the tranny. Again, the greater the load, the louder and longer the noise.
And I've also noticed a small buzzing noise whenever the gear selected is D. If I put it in P,R,N,2 or 1 the buzzing is not present.
I've never heard a transmission make a noise like that. I don't think it is the transmission, but I can't tell you what could be making that noise.
Mark, thanks for checking and replying back. I've never heard anything like it before. But all the other vehicles we have are manuals, so I'm not too smart on the ATs.
Originally Posted by JWA
Believe it or not the noise sounds like ignition noise through the radio---is that even possible for your situation?
If so its most likely a bad ground connection somewhere in the radio circuit.
Not sure that's helpful but just an idea.
JWA- Had not thought of that. The radio is off during the video and for that matter most of the time we're driving. But I suppose that it could still come through if it was a grounded wire. I'll try pulling the fuse for the radio to see if that's what it is. Will be a few weeks before I can reply back. I'll be afloat for the next three weeks on a haze grey big deck.
