1969 f-250 ignition problems
Old Jul 6, 2013 | 11:47 PM
tuckerbandit's Avatar
tuckerbandit
i'm having problems with my ignition system and need some help. When I take the ignition switch to start the truck starts up, but when I release the switch the ingine turns off. Any suggestions?
Old Jul 7, 2013 | 12:40 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1969 F250
Originally Posted by tuckerbandit
i'm having problems with my ignition system and need some help. When I take the ignition switch to start the truck starts up, but when I release the switch the engine turns off. Any suggestions?
Look at the switch, see if the wires have been spliced to the dash harness by using a pigtailed harness/plug.
If not, the original POS switch is still in place, replace it as it was notorious for shorting out and catching FIRE!
No recalls back then, dealers were supposed to notify customers of defective switch. Some did, some did not.
D1AZ-11572-C .. FoMoCo "Service Part Replacement" Ignition Switch Kit - Includes pigtailed harness/plug (Motorcraft SW-1054). Replaced POS C8AZ-11572-A switch.
Applications: 1968/69 F100/750 & Econoline / 1970 F100/750 & Econoline before serial number G90,001 // 1968/69 all FoMoCo Passenger Cars.
Old Jul 7, 2013 | 03:04 AM
The Masked Rider's Avatar
The Masked Rider
O!!! and trust Bill on that. A friend of mine 68' caught fire because of that darn switch and burnt to the ground. Once it gets started - hard to put it out. Sad thing was he had just pulled out his floor mounted extinguisher to install new carpet.
Old Oct 20, 2014 | 11:31 AM
69issofine's Avatar
69issofine
it's either the switch or the resistance wire is broken
ovalholic
19
Jun 17, 2021 07:34 PM
K9spike
Nov 6, 2017 09:08 AM
GUYDON
32
Jun 5, 2017 07:25 PM
hogbus
Sep 24, 2012 10:17 AM
workingdog
Jan 7, 2008 06:43 AM
