Left brake light not working
Old Oct 20, 2014 | 10:10 AM
wtx66f100's Avatar
wtx66f100
My left brake light quit working yesterday. The right one works fine and the running lights on both sides work. Anyone have a suggestion on what to check first? I went ahead and replaced the bulb just to make sure it was good but no luck.
Thanks
wtx66f100
Old Oct 20, 2014 | 10:44 AM
hillcountryflt's Avatar
hillcountryflt
They joys of wiring in these older vehicles. Since one brake light works, that pretty much eliminates the switch. I would be starting at the tail light and checking connections back from there.
Has your wiring been cut into a bunch, say for trailer lights, etc. If so, I would eye those areas closely.
Also you might want to print out a copy of the wiring diagram and kind of follow the path of the correct circuit/wire.
Ford Truck Technical Drawings and Schematics - Section H - Wiring Diagrams
These diagrams have consumed much of my attention where troubleshooting wiring issues.
Old Oct 20, 2014 | 10:48 AM
wtx66f100's Avatar
wtx66f100
Appreciate the help. Right after I posted the question I went out and started at the wiring and just like you suggested there is a trailer wiring harness spliced in and the problem was a bad connection. Fixed the splice and things are good.
Thanks
wtx66f100
Old Oct 20, 2014 | 12:46 PM
351Cleveland C4's Avatar
351Cleveland C4
Make sure your turn signal lever is centered. That will Cause this problem if it's not.
Raymond Tomlinson
Dec 10, 2014 03:59 PM
Rose Clifford
Dec 30, 2011 11:41 PM
1976HighBoy
Nov 10, 2010 09:52 AM
77hiboyboy
Electrical Systems/Wiring
May 15, 2003 09:29 AM
