Cooling problems, sort of
Old Jul 10, 2013 | 05:44 AM
dataman's Avatar
dataman
Originally Posted by npccpartsman
AMEN, David. I just read a thread on the .ORG where, even after switching to ELC, there were still the same problems with plugging and gelled coolant. It all goes back to proper maintenance. PERIOD.
Exactly. Once the gold gels up, I don't see any way to get it all out without replacing the coolers. More and more I don't like the idea of mixing 2 different coolants if you can't get one completely out. If you attempt to use VC-9 and it starts to move a lot of stuff around, I think your headed to a plugged cooler anyway. I think I'd rather be knee deep in water from flushing the thing all day long than try to do it a quicker way. Right now my temps are fairly good so I'm still thinking and searching for a place to get this done.
Old Jul 10, 2013 | 05:49 AM
dataman's Avatar
dataman
Originally Posted by 04badford
Fred, the VC9 flush done right will clear all ,only if the oil Cooler is not that plugged . Hype on all this make me want to just SHr3em. . do the flush, vc9,simple green, pull the block plugs and thermo, flush well with tap, and then get down and dirty with distilled flush20 gal flush pulling block plugs, don't for get the Heater core line. its going to be a wet day.
I've read about VC-9, the good and bad, worries me a bit. My temps are pretty good right now but kinda weird. At 70 degrees outside the delta can be as high as 10 degrees. At 95 outside the delta can be as low as 3 or 4 degrees but the temps are above 200. like 204/207. I've seen 197/207 even. I'm wondering if these are good enough to just do a lot of flushing or should I really consider the VC-9?
Old Jul 10, 2013 | 05:52 AM
npccpartsman's Avatar
npccpartsman
Well......by gel I mean goo, not the hard deposits that form inside the oil cooler fins. I mean snotty goo. I don't know if it takes a chemical flush to remove that junk and I certainly don't advocate a chemical flush UNLESS you have a temp problem and plan on changing your oil cooler. I wonder if a simple green flush like what is used to clean up after an oil cooler rupture would remove the goo without cutting a bunch of rust/scale/deposits loose inside the cooling system.....
Old Jul 10, 2013 | 05:53 AM
dlibson's Avatar
dlibson
Flush, fill, and stop the worrying!
Your temps are fine. Normal! Just flushing it will get you a ton of sand cast out of the system and it will be good to go!
Old Jul 10, 2013 | 05:54 AM
npccpartsman
I honestly don' see anything wrong with your temps. I don't even consider them high. Pretty normal actually
Old Jul 10, 2013 | 06:15 AM
bismic's Avatar
bismic
The "Restore" cleaner is for cleaning out the gelled coolant. The "Restore Plus" is for the rust and scale (like VC9) and is a pretty harsh cleaner.
As stated by others above, I also would try a water flush first since you have pretty good temperature values.
Old Jul 10, 2013 | 12:28 PM
dataman's Avatar
dataman
I worry about everything, haven't figured out how not to. Explains the gray hair.
Like you said, flush and fill. That's what we're going to do.
janoschxy
Jul 18, 2019 02:24 PM
StanleyZ
6.4L Power Stroke Diesel
51
Oct 26, 2014 09:30 PM
96blackford
13
Jul 30, 2013 02:24 AM
Dlinzy
Feb 17, 2012 10:35 PM
RangerPilot
1983 - 2012 Ranger & B-Series
Apr 23, 2006 12:12 AM
