460 Rebuild
Old 07-04-2013, 02:08 PM
Cody's F100's Avatar
Cody's F100
Cody's F100 is offline
460 Rebuild
rebuilding a 460
using stock heads and intake
putting in pistons and cam,
any recommendations for pistons to get me 10:1 compression
and recommendations for a good mild performance cam?
engine does not need bored out
Old 07-04-2013, 02:55 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Old 07-04-2013, 02:57 PM
Cody's F100
thanks!
Thank the lord for the Big Block Ford
Old 07-04-2013, 05:37 PM
mark a.'s Avatar
mark a.
mark a. is offline
Being as you don't have pistons yet how do you know it does not need bored ? Different pistons need different clearances. I"d just figure on going to the next over size, you don't want to buy a set and find out they won't work.
Old 07-04-2013, 05:58 PM
HIO Silver's Avatar
HIO Silver
2x with Mark... if rebuilding yourself, bring the block to the machinist and get the specs for the new parts. If not, always get the invoices from the machine shop so you have a record on what parts were installed.
Old 07-04-2013, 06:07 PM
Cody's F100
Because it has such little wear I am tempted to just hone to .010 over then buy over sized pistons, I just wanna know what some good flat top or dome top pistons I should buy and what kinda performance street cam works good in these engines
Old 07-04-2013, 06:15 PM
HIO Silver's Avatar
HIO Silver
The bores may not appear to have telltale wear but have ya actually measured determine whether it has been previously bored?
Pistons come .010 over? I know bearings do, and pistons for motorcycles do, but car/truck pistons?
Old 07-04-2013, 09:11 PM
whc8100's Avatar
whc8100
whc8100 is offline
rebuilding a 460
Year of your heads will determine what pistons you will need to get the proper compression ratio. A 10:1 iron headed 460 with a mild cam will be very picky on fuel. What is the intent of your build, towing, racing...? My mild cam 460 at 9.3:1 needs 91 oct for anything other than light criuse in cool weather. I would get it bored over and start with straight bores and a good ring seal, money well spent.
Old 07-04-2013, 09:22 PM
quickshift's Avatar
quickshift
quickshift is offline
You MAY find this of some use. Scotty and Randy are very knowledgeable as can be seen in their reply's.
Cam and C/R - 460 Ford Forum
Old 07-04-2013, 09:28 PM
whc8100's Avatar
whc8100
whc8100 is offline
Yup got my cam and some other parts from Scotty AKA The Mad Porter. Top notch guy with a world of knowledge on Big Block Fords.
DeathPumpkinF-250
02-16-2019 10:58 PM
Barnfind79
02-06-2016 08:26 PM
SuperCruiser78
02-05-2014 02:25 PM
78bigblock
12-04-2001 05:54 AM
79BroncoJD
08-28-2001 11:52 PM
Quick Reply: 460 Rebuild
