94 7.3 IDIT A/C question
Old Jul 4, 2013 | 08:12 AM
snowdog79's Avatar
snowdog79
Question 94 7.3 IDIT A/C question
Does anyone know off the top of their head if the A/C components are the same on the 7.3 as they are on the other motors from the same year? My compressor, or the clutch at least, is not functioning. I've tested the electrical to it and it all checks out. Not sure if the compressor is seized or it's just the clutch, but I might as well replace all the pieces and have it flushed and filled.
Thanks!
Old Jul 4, 2013 | 05:06 PM
airdale94's Avatar
airdale94
If the pulley won't freewheel with the belt on the clutch hub is seized up. If the belt doesn't squeal until the A/C is turned on then it's your compressor.
Old Jul 4, 2013 | 11:20 PM
Red454sedgwick's Avatar
Red454sedgwick
Mine wouldn't engage all the time, I took the front plate of the clutch off and cleaned it, that fixed my problem, Its worth a try before you start buying new stuff.
Old Jul 5, 2013 | 08:12 AM
snowdog79's Avatar
snowdog79
I'm pretty sure the compressor is seized solidly. So the question remains which other motors use the same compressor?
Old Jul 5, 2013 | 08:32 AM
Chevy_Eater's Avatar
Chevy_Eater
Per Rock Auto:
6 Groove.
<table id="buyersguidetable"><tbody><tr class="part0"><td>FORD</td><td>BRONCO</td><td>(1990 - 1996)</td></tr><tr class="part1"><td>FORD</td><td>E-150</td><td>(1990 - 1996)</td></tr><tr class="part0"><td>FORD</td><td>E-250</td><td>(1990 - 1996)</td></tr><tr class="part1"><td>FORD</td><td>E-350</td><td>(1990 - 1996)</td></tr><tr class="part0"><td>FORD</td><td>ECONOLINE SUPER DUTY</td><td>1996</td></tr><tr class="part1"><td>FORD</td><td>F-150</td><td>(1990 - 1996)</td></tr><tr class="part0"><td>FORD</td><td>F-250</td><td>(1990 - 1997)</td></tr><tr class="part1"><td>FORD</td><td>F-350</td><td>(1990 - 1997)</td></tr><tr class="part0"><td>FORD</td><td>MUSTANG</td><td>(1994 - 2004)</td></tr><tr class="part1"><td>FORD</td><td>TAURUS</td><td>(1993 - 1995)</td></tr><tr class="part0"><td>FORD</td><td>WINDSTAR</td><td>(1995 - 1998)</td></tr><tr class="part1"><td>LINCOLN</td><td>CONTINENTAL</td><td>(1993 - 1994)</td></tr><tr class="part0"><td>MERCURY</td><td>SABLE</td><td>(1993 - 1995)</td></tr></tbody></table>
8 Groove.
<table id="buyersguidetable"><tbody><tr class="part0"><td>FORD</td><td>E-350</td><td>(1993 - 1997)</td></tr><tr class="part1"><td>FORD</td><td>ECONOLINE SUPER DUTY</td><td>(1996 - 1997)</td></tr><tr class="part0"><td>FORD</td><td>EXCURSION</td><td>(2000 - 2003)</td></tr><tr class="part1"><td>FORD</td><td>F-250</td><td>(1993 - 1997)</td></tr><tr class="part0"><td>FORD</td><td>F-350</td><td>(1993 - 1997)</td></tr></tbody></table>
Brian McCart
May 24, 2016 01:53 PM
Herb Brooks
6.4L Power Stroke Diesel
Sep 8, 2015 12:01 PM
killacash
Escape & Escape Hybrid
Jul 12, 2013 09:07 PM
Civilian
Jan 10, 2011 05:09 PM
PeterBrazier
1997 - 2003 F150
May 27, 2010 09:38 AM
