2001 sport trac power door locks will lock not unlocking
Do both doors lock when the switch from either door is pressed for Lock? Do you have remote keyless entry, and if so, does both Lock and Unlock work from the keyless fob? Do you have a test light or multimeter, and are you comfortable removing the door panel and taking some measurements?
-Rod
-Rod
Okay, with the door panel off and the multimeter, you should be able to check for voltage to the door lock motor. If there's voltage there, the issue is the lock. Not likely since neither side unlocks. If there's no voltage at the motor, then start working your way back to the switch. If there's voltage in to the switch but not out from the switch, the switch is the issue. If there's no voltage to the switch, then you need to work your way back to the fuse, etc. You also need to ensure you have a good ground to the switch as well.
-Rod
-Rod
The solenoids work by reversing the polarity. You mention you have power and ground at the actuator. When the lock/unlock switch is not being pressed, both wires to the solenoid should be at ground potential. When you press lock, one wire should have battery voltage. When you press unlock, the other wire should have battery voltage. Is that the way it functions? If not, disconnect the lock solenoid and check the function at the output of the switch. Does it work correctly now?
Would the wiring diagrams help you? If so, I could provide them.
-Rod
-Rod
Driver door power lock won't unlock
I would be very grateful for any assistance.
Help us understand exactly your issue. From the driver's door lock switch do all doors both lock and unlock, or only lock? From the passenger door lock switch does it lock and unlock all doors except the driver's door? Does the passenger switch lock or unlock the driver's door, or just cause nothing to function on the driver's door?
What year is your Explorer?
-Rod
-Rod
jonathandennell
06-06-2007 06:29 PM
