Bronco II Ford Bronco II
Power door lock issues
Old May 22, 2005 | 05:54 PM
m thatcher's Avatar
m thatcher
Gentlemen,
1988 XLT. Power window work fine. Driver's door lock works, including locking/unlocking rear hatch. My problem is with the pasenger door.
The door itself usually opens only from the inside latch. The power lock button works if I press "lock" in that it locks the other two doors, but has no effect on the passenger's door, but doesn't do anything if I press unlock. I can't unlock the door with the key or the little **** that sticks up either.
So I removed the door panel and started taking things off and I'm struggling prying the actuator itself down and out, and disconnecting the leads to test to see if the actuator is getting power from the switch. I can't see any release tab on the connector. Any dismantling tips?
As always thanks for you excellent guidance.
Old May 23, 2005 | 03:49 AM
87 XLT's Avatar
87 XLT
It's a pretty simple circuit. What happens when you use the drivers door switch & what happens when you use the passenger door switch?
I'll see if i can find my wiring diagrams in the morning.
Old May 23, 2005 | 02:01 PM
87 XLT's Avatar
87 XLT
All the lock motors are spliced together & all the switches do is reverse polarity thru the motors.
Heres how the unlock circuit works. From the drivers switch to unlock relay is on pink/light green & theres a wire spliced into this from the passenger switch.
With the drivers door switch at the unlock position check for voltage at the passenger lock motor on pink/orange. Then check again with the passenger door switch at the unlock position.
BTW, this is how my 87 is wired, guessing your is wired the same.
Have you got the wiring diagram for your 88?
Old May 24, 2005 | 08:42 PM
m thatcher's Avatar
m thatcher
Unfortunately the B2 I bought cannot be licensed and I'm returning it to the used car lot I brought it from. So at this point I'm preparing to wrestle an old man over the value of my improvements. Bummer.
Old May 25, 2005 | 01:10 AM
87 XLT's Avatar
87 XLT
Yeah, you did spend some time & money geting the engine running right. Hopefully that will be worth a few bucks to you.
Good luck with it.
