Problems with Depo clear corner lights?
Old Jul 2, 2013 | 04:50 PM
Fastback460's Avatar
Fastback460
I installed some clear corner lights from Depo a couple of months ago http://www.ebay.com/itm/92-96-97-F-150-250-350-Super-Duty-Bronco-Clear-Bumper-Lights-Corner-Signal-Lamps-/350789875146?pt=Motors_Car_Truck_Parts_Accessories&autorefresh=true&vxp=mtr&hash=item51acb4b5ca&nma=true&si=JlwZIXvd3EzH1BS%252F2iPAqmSkBZU%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
They have been fine up until last week.
It has gotten really humid lately and now both of the corner lights(not the turn signals, just the small corners) are covered with moisture on the inside of the lens. They started out with just a little, and I figured it was no big deal it will probably dry out. I was wrong, It's only getting worse
Has anyone else ever had this problem with these lenses? Or is it just me.
Old Jul 2, 2013 | 05:09 PM
Diesel_Brad's Avatar
Diesel_Brad
That is TYPICAL of any aftermarket lens'.
before I install any of them, I take clear RTV and seal the top and both sides(where the lens meets the housing). That way water can not get in.
I also take a 1/8" drill and makes holes in the two lower corners as drains
Old Jul 2, 2013 | 05:19 PM
Fastback460
Thanks Brad, I'll take em' out, let them dry, and seal them both up better.
Now that you mention it, the turn signals came with drain holes built in. Probably why those are fine.
troverman
2017 Ford SVT F150 Raptor
Sep 13, 2017 10:09 AM
uknunn
Aug 6, 2017 01:09 PM
rex2908406
Dec 6, 2011 12:22 PM
pauljackmax610
Jun 7, 2010 12:22 AM
sonic
Jan 12, 2006 11:34 AM
