What year did the grill change on the 87-96 era ford?
The old ones have a more square light when do they have the more modern grill?
Just sold my mint 79 ford pickup and looking to get into one of these.
Thanks guys..
Thanks guys..
Can the older grill interchange easy enough? Would it mean front clip swap? Fenders and grill? Plus rad support?
Just wondering if it could be converted. Looking at a 88f350
it went 87-91 was the brick nose and 92-97 was the newer grille. To do a swap, you need the grille, lights, fenders and the hood, not sure if you need the rad support and hood hinges or not
87 to 91, then 92 to 97. but 83 to 97 front end swap is pretty much a bolt on deal.
the bumper mounts are different, but nothing a drill bit can't fix.
to switch from one nose to the next you need everything, including radiator support.
I'd like to just find a 96/97 but they are hard to come by and can be a little on the pricey side. Wondering what year diesel is the best as well?
And how many k's or miles they pack er in with most common issues as well??
If he's calling the body style that the 97 F150s use the "Kenworth style nose" that's the first time I've ever heard it called that. I've heard people call it "Taurus style" though.
