Power Locks Quit
Several years ago I did the actuator fix by putting aluminum foil over the thermistors. Now, all the locks work manually except the front right door which is unlocked and I can't lock it with the key or by trying to push the button down. I'll pull the door panel in the next couple of days to see what's going on there. I can't help but think this is related, but don't know how. When I'm in there I'll check to see if the actuator is getting voltage from the relay when the lock/unlock button is pressed. All the fuses are okay.
What could cause all four actuators to quit at the same time? I still get the horn chirp and park light flash when I hit the remote lock twice.
Any ideas are appreciated.
