Brake adjust. what order
Old Jun 30, 2013 | 05:29 PM
obscurity's Avatar
obscurity
Bleed then adjust
Adjust then bleed
Doesn't make any difference
Just curious,
Old Jun 30, 2013 | 05:40 PM
Kurt G.'s Avatar
Kurt G.
John, I adjust then bleed then check adjustment again. I use to be easier when I had a rack to do it.
1948 F1dude's Avatar
1948 F1dude
I would adjust then
bleed Right rear then left rear then right front then left front .. That is how I have always done it . But their always other opinions .........Dude
Old Jun 30, 2013 | 06:06 PM
Kurt G.'s Avatar
Kurt G.
Originally Posted by 1948 F1dude
I would adjust then
Ditto the order, sorry I forgot that.
Old Jun 30, 2013 | 06:16 PM
51MHF5's Avatar
51MHF5
And the reasoning is that you always start the farthest away from the master cylinder and work in sequence to the closest.
Old Jun 30, 2013 | 07:52 PM
1oldtimer's Avatar
1oldtimer
To me the adjustment would be the last step in the process.
Old Jun 30, 2013 | 08:03 PM
Harrier's Avatar
Harrier
Thanks! I was wondering why that order. It makes sense now. Now if I can remember that when I get to that point.
Old Jun 30, 2013 | 08:15 PM
The Horvaths's Avatar
The Horvaths
Adjustment needs to be close enough that you don't risk pushing the piston out of the wheel cylinder or attempts to bleed will end in great anguish and eternal gnashing of teeth. I choose to adjust, bleed in order, drive a bit and readjust as needed.
ChuckRob
Jul 24, 2013 07:15 PM
Crick07
1983 - 2012 Ranger & B-Series
Feb 3, 2010 12:56 PM
cacarroll
May 6, 2007 10:21 PM
inspector99
23
Nov 29, 2006 11:50 AM
51truck
Feb 3, 2003 07:56 AM
