rear brake help
Old Nov 18, 2006 | 04:55 PM
inspector99's Avatar
inspector99
rear brake help
96 f150,i am putting new shoes,drums on my truck.Got the shoes on,but when i put the drum on,it is a very tight fit.The parking brake seems to be too tight,but my manual says there is no adjustment on the cables.Is there anyway to loosen them up without replaceing the cables?They are not seized.
Old Nov 18, 2006 | 05:03 PM
sbowling79's Avatar
sbowling79
does that not have the adjustment screw at the bottom?
Old Nov 18, 2006 | 05:08 PM
inspector99
i dont know,thats what im asking,is there an ajustment somewhere?
Old Nov 18, 2006 | 05:09 PM
inspector99
the brake adjustment scew is all the way in
Old Nov 18, 2006 | 06:33 PM
sbowling79's Avatar
sbowling79
did you replace the retractor and hold down springs? they may be worn and causing your problem
Old Nov 18, 2006 | 08:41 PM
inspector99
i replaced all the springs with a spring kit
Old Nov 19, 2006 | 10:15 AM
inspector99
acts like the e brake is too tight,but the cables are working
Old Nov 19, 2006 | 11:26 AM
Conanski's Avatar
Conanski
First make sure you have everything asembled correctly. If it is it'll look like this..
http://cgi.ebay.com/ebaymotors/9-For...49689112QQrdZ1
You can see the auto adjuster at the bottom-center of the assembly, this should be all the way in. There is a linkage on the drivers side just ahead of the axle where the 2 rear park brake cables meet. The longer cable that goes to the pass side has an adjusting nut that will affect the overall park brake preload... it could be too tight for the new pads.
Old Nov 19, 2006 | 12:35 PM
inspector99
theres no ajusting nut on it anywhere
Old Nov 19, 2006 | 01:18 PM
inspector99
i`m thinking it must be the e brake cables,they are the original,maybe seized enough to not let the brake off completely,the passenger side is getting hot when i drive
Old Nov 19, 2006 | 01:48 PM
andym's Avatar
andym
Yes there is and it is definitely not the cables. There is a starwheel at the very bottom between the shoes, and it has to be screwed all the way in before you put the drums on. After the drums are on, you manually adjust them out until the shoes contact the drum all the way around.
Old Nov 19, 2006 | 01:53 PM
inspector99
the starwheel is scewed in all the way
i cant find any adjusting nut on the e brake,on the older ones there was one where the two cables connect to the main cable,but not on this one
Old Nov 19, 2006 | 01:56 PM
andym's Avatar
andym
Ok, I see what you're saying, but adjusting the cables isn't going to help in this case. If the starwheel is all the way in and the drum still won't go on, then it's either not together right (unlikely) or you got some cheap or defective parts.
Old Nov 19, 2006 | 01:58 PM
inspector99
the drum went on ,but its tight
Old Nov 19, 2006 | 01:59 PM
inspector99
the drum went on ,but its tight,the drivers side seems ok,but the passenger side is tight
