ok when i got almost anything over 40 my spedo needle will go nuts swinging all over back and fourth and occasionally stop at the correct speed and then keep going again. do i have to change my whole cluster and ifso what else do i have to factor in. mine is a 300 5spd 4-4. i know it needs to come from a manual truck and a gas truck but what yrs can i use it from and does motor size matter or if i use from a gas f250 or 350 and would it have to be from a 4-4 truck. need to know asap. thanks
i took that little sensor off the top and cleaned it up some. didnt know that little thing could realy go bad. i looked on ebay for one but there were 2 different styles i seen but it looks like it might work but i would like to know before i buy it. first pic is mine second is the one i want off ebay http://www.f150forum.com/attachments...2354422868.jpg Ford F150 Forum - Community of Ford Truck Fans
thanks. the sensor wasnt gunked up it was a little rusty tho and i took the cover off to clean the gears and change the oil it didnt look to bud wasnt gunked up like i thought it was but i do think it needed the change and the cover was seaping a little.
