Creaking
Old Jun 28, 2013 | 08:59 AM
ccbrett's Avatar
ccbrett
Creaking
Hey any of you guys get any creaking noises from under your floor pans when going slow over bumps wondering if the body bushings are doing it or what nothing looks loose maybe normal not sure thanks.
Old Jun 28, 2013 | 08:51 PM
Elmo154's Avatar
Elmo154
Groaning in the rear
Yes, mine is in the rear. Sometimes when starting sometimes when going over speed bumps. I suspect it is the rear body mounts.
Lots of people have talked about groaning in the front caused by body mounts but not too much about the rear.
I have not heard of a solution except change out the mounts.
Old Jun 28, 2013 | 09:14 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
check the little nylon sliders in your spring packs. when those wear out they tend to creak...and you'll only hear it when the leaf pack is twisting
they're about 3" round discs
Old Jun 28, 2013 | 09:34 PM
ccbrett's Avatar
ccbrett
Thanks guys wonder if you can grease the nylon pieces.
Old Jun 28, 2013 | 10:39 PM
EXv10's Avatar
EXv10
Sure, just spread them a little and shoot some grease in there, same with the body mounts.
Joshua Sirchuk
Aug 19, 2016 03:33 PM
bearhugger
Apr 23, 2011 08:29 PM
fordboy67
Aug 6, 2008 01:56 PM
oldmansimek
Aug 18, 2006 02:21 PM
brittonairinc
Jan 10, 2006 08:32 PM
