Front Sway Bar End Link Problem
Old Jun 30, 2013 | 09:21 AM
EXv10's Avatar
EXv10
There is a problem with the upper anchor design which I did a thread on. The bolt is "waisted" and too loose on the upper end and getting it extremely tight will do nothing for the problem.
Old Jun 30, 2013 | 01:55 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I saw your thread on that Brent. I'm going to mess around with it a bit...but will probably end up doing what you did
Old Jun 30, 2013 | 02:28 PM
EXv10's Avatar
EXv10
They made the top bolt skinny in the middle so it would pass easily through the anchor and fit snugly in the bushing which left it way too loose inside the anchor. Big companies screw up too, like those wimpy bolts in the exhaust manifolds, and just a couple threads in the aluminum heads. My Dorman struts are working very well.
piperpilot
Nov 4, 2019 02:12 PM
harley4jcs
Jan 21, 2015 10:33 AM
robles4242
Sep 21, 2010 09:44 PM
zavierbr
May 20, 2009 12:59 AM
cowboyup1988
Mar 7, 2009 09:00 AM
