Sponsored by: Real Truck
sway bar link?? HELP!
Old Mar 6, 2009 | 11:48 AM
cowboyup1988's Avatar
cowboyup1988
Exclamation sway bar link?? HELP!
i replaced the bushings in my swaybar and the lnks but i forgot how the links bolt back up! i know stupid me but i need some help...i have an 04 f250...does the "wide" end bolt to the swaybar or does it bolt to the frame? there is a "wide" end and a skinnier end....
Old Mar 6, 2009 | 12:11 PM
elee3's Avatar
elee3
2004 F250 Sway Bar Bushing Replacement There are some pictures in this link. It looks like the wider (metal part) goes down.
Old Mar 6, 2009 | 06:59 PM
1975StroppeBaja's Avatar
1975StroppeBaja
I actually installed mine backwards when I replaced them and had to go back and correct my write up. I asked on here and also checked out quite a few other SD's in person before finding out I had them backwards.
The pic from the write up shows the right way.
Old Mar 7, 2009 | 07:16 AM
elee3's Avatar
elee3
[QUOTE=1975StroppeBaja;7229902]I actually installed mine backwards when I replaced them and had to go back and correct my write up. I asked on here and also checked out quite a few other SD's in person before finding out I had them backwards.
Jason, I think that I have provided people with this link to your right up about three times in the past week. I used it as a reference when I replaced my bushings and it was very helpful. I have looked at the other right ups that you have done and they are all very good. Thank you, and keep up the good work. Rep points to you.
Old Mar 7, 2009 | 09:00 AM
1975StroppeBaja
Thanks elee3! Glad to hear people are getting some use out of them!
Jason
