6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Fuel additive?
Old Jun 26, 2013 | 07:30 PM
Black Snow Slide's Avatar
Black Snow Slide
Fuel additive?
My 09 6.4 has been drinking diesel fuel strait up with no additives. So what's the story? Do you use an additive to make make you truck run better? If you do, what one? Where do you buy it? Why do you use the one that you use? Rate it from 0-10. Thank you.
Old Jun 26, 2013 | 07:55 PM
golfmedik's Avatar
golfmedik
I run Diesel Kleen's grey bottle from spring til late fall and love it. I use the white bottle in the winter. I started using in w long time ago in my 7.3L Excursion. The main reason I do this is because it adds lubricity to the engine parts. With the diesel fuel low in sulfur now, the engine(injectors) doesn't get lubricated near like they used to. I've seen a 1/2 mile per gallon improvement in my X, so I 've ran them since my '10 F350 was new. Lots of guys run this type, Ford's cetane booster or a few others. Bottom line is, the engines do not mind it, the injectors stay lubricated and the 7.3s actually run a little more quiet with the additive in there. It has also reduced the regens in my 6.4L by adding mileage between the regens and by shortening the regens at the same time. Higher cetane, a little less soot. You can buy Diesel Kleen at WalMart, Tractor Supply and most any national auto parts stores. To me, it's like an ounce of prevention.
Old Jun 26, 2013 | 08:02 PM
bubbasz1's Avatar
bubbasz1
The primary reason to add additives is for lubrication of the pumps and injectors. Second reason is to boost cetane , thirdly is to keep fuel from gelling in cold weather. Many things are claimed about additives but that is the three top reasons.
I use Ford cetane boost.
Old Jun 26, 2013 | 08:12 PM
WMDPSD's Avatar
WMDPSD
I run ford and power service, can't tell any diff. Between the two
Old Jun 26, 2013 | 10:40 PM
RM2738's Avatar
RM2738
Power Service DK, Gray Bottle. No noticeable difference. Just cheap assurance that the H2O is demulsified, pumps and injectors have a little extra lubrication and cetane numbers are up a few points.
Old Jun 27, 2013 | 03:41 AM
Delta2142's Avatar
Delta2142
I use XDP Plus and it seems I have less water in the fuel.
Old Jun 27, 2013 | 08:11 AM
GSchretter's Avatar
GSchretter
I use Ford cetane since I bought my truck.
I missed one or two times and the truck started to sound like an older diesel (louder and rough diesel noises)
Also nice to have several bottles with you if you accident put regular gas in her. (Did it once and never again will I fuel my cars up hung over).
LOL...
Old Jun 28, 2013 | 05:54 AM
deerslayer64d's Avatar
deerslayer64d
I also use the ford cetane sene I got my truck , the main reason I do is to keep things Lubricated
Old Jun 28, 2013 | 04:09 PM
Black Snow Slide
I bought 6 bottles of the Ford Cetcan. 50 miles on first tank with 4 oz added. Seems quieter and smoother.
Old Jun 28, 2013 | 09:07 PM
RM2738's Avatar
RM2738
Are you saying it seems you have less water when you drain your HFCM?
I'm sure it's a coincidence. Maybe you're using lower bio content fuel.
That would concern me... I would think that less water is being demulsified from the diesel and more is making it past the filter.
Old Jun 29, 2013 | 03:48 AM
Delta2142's Avatar
Delta2142
Yes and probably right. I'll try the Ford Cetane next time
diamondrcattle
17
Mar 7, 2014 08:21 AM
zgoo
Feb 13, 2013 11:30 AM
jmcquarry
6.7L Power Stroke Diesel
48
Dec 8, 2011 09:09 AM
k_conner
47
Jul 11, 2009 09:14 AM
StrokeThis96
Nov 27, 2007 07:22 PM
