85 f150
Old Jun 26, 2013 | 03:30 PM
monkey jason's Avatar
monkey jason
85 f150
i have an 85 ford f150 that starts and idles fine but hesitates under load. i have rebuilt the carb, put on a new fuel pump and fuel filter, and new plugs. but when i put on a new distributor cap, rotor cap and plug wires it got drasticly worse. plug wires are correct. any ideas would be great!
Old Jun 26, 2013 | 05:40 PM
Franklin2's Avatar
Franklin2
What engine? Have you checked the timing?
Old Jun 26, 2013 | 08:01 PM
monkey jason
it's a 300 6, timing is good.
Old Jun 26, 2013 | 08:50 PM
Gary Lewis's Avatar
Gary Lewis
I've seen several harmonic balancers that have slipped. The rubber gets old and let's go and the outer ring slips and the timing marks are then wrong. I would suggest pulling the plugs, holding your thumb over #1 plug hole, and turn the engine over with a breaker bar. When you are coming up on #1 TDC you will feel pressure on your thumb. Stop there and insert a soda straw long enough it won't fall in. Continue cranking until the straw quits coming out and you are at TDC. Check the timing mark. If it isn't very close your balancer has slipped and needs to be replaced.
Old Jun 26, 2013 | 10:27 PM
monkey jason
Harmonic balancer looks good.
Old Jun 26, 2013 | 10:39 PM
ctubutis's Avatar
ctubutis
It may look good, but it's still a good idea to verify that by bringing #1 to TDC and making sure it lines up with zero.
Old Jun 26, 2013 | 11:28 PM
Gary Lewis's Avatar
Gary Lewis
Most harmonic balances that have slipped look good. It is just that the marks or off that is the indicator. Having said that, I had one recently where the outer ring was cocked.
Old Jun 26, 2013 | 11:39 PM
monkey jason
By good i mean lines up.
Old Jun 27, 2013 | 07:19 AM
Gary Lewis's Avatar
Gary Lewis
I would check it, for sure, by finding TDC. Pull the plugs, put your thumb over #1, and when you fell pressure stop. Put a straw in and slowly turn until the straw quits coming out. Check where the timing mark is.
Old Jun 27, 2013 | 02:19 PM
1986F150six's Avatar
1986F150six
The timing of an original 1985 4.9L engine is controlled by the computer. Did you disconnect the spout wire to check the timing?
Regarding the harmonic balancer, listen to the previous posters. They know their stuff!
With the engine stopped, using chalk or a crayon, draw a line straight across the face of the balancer and then drive [if possible]. When you look at the balancer again, if the line is broken, it will indicate that the outer ring has shifted.
Looking at your 1st post made me think of this: since you state that after replacing distributer cap, rotor and plug wire, it ran "drastically worse", why not put each old part back on [one at a time] and see what is causing the worsening?
Old Jun 27, 2013 | 09:25 PM
monkey jason
Im starting to think the distributor isn't advancing, does that mean the computor is going bad?
Old Jun 27, 2013 | 10:08 PM
Gary Lewis's Avatar
Gary Lewis
If the computer is unhappy about anything it will lock the timing into limp-home mode of about 10 degrees BTDC. Check to see if it is showing codes.
cjcloward
Aug 18, 2017 07:57 PM
drjoe171
Mar 6, 2012 09:35 AM
fzeed
24
Nov 18, 2008 04:45 PM
jharrington
Nov 14, 2008 09:12 PM
kev50
Jun 21, 2002 11:11 PM
