timing changes all by itself 92, 4.9L auto
Old Nov 30, 2010 | 07:12 PM
drjoe171's Avatar
drjoe171
I set the timing with spout off to 10btdc
reconnected spout and it didn't chang4e what the timing light showed.
Didn't really care because it ran.
Cruising at 55, slight accel and it pings like its going to hurt itself.
back off, hold steady at 55 for a few seconds and accelerate again and NO ping, hard romp up to 70.
Kinda does the same thing from a dead start. Can never really tell when it's going to ping.
If it was a regular distributor, I would guess a sticky vac advance plate or diaphragm, but this is a fancy computer controlled fuel injected model.\\What am I missing?
Thanks
Old Nov 30, 2010 | 10:36 PM
fordman1090's Avatar
fordman1090
What condition are the plugs in? Wires? Cap? Rotor?
Is the timing staying at 10 BTDC after you drive a while? the distributor isnt lose, is it? Does it ping if you drive it without the spout connector plunged in?
See what you find and hopefully this will bump the post and someone will know more about what could be causing it.
Old Dec 1, 2010 | 02:36 AM
drjoe171's Avatar
drjoe171
new cap wires, plugs and rotor but you got me thinking...it MAY be cross talk between the plug wires, eh?
I've seen some posts about how critical some of these trucks are with respect to routing plug wires, but I don't remember exactly where I saw that topic.
This thing starts, runs and shifts PERfectly, other than that random ping thing.
Thanks
Old Dec 1, 2010 | 10:16 AM
cj06's Avatar
cj06
on the distributor the pin that holds the gear on can sometimes shear off and your gear will slip on the shaft witch will change your timing !
Old Dec 1, 2010 | 12:12 PM
danr1's Avatar
danr1
Sounds like a intermittent connection in the spout circuit, timing should have jumped up a few degrees right when you pushed the spout jumper back in place while idling, sounds like you know that.
Did you check it for codes?
Get "212" "219" CM code? or 213 KOER code? just to pick a choice few.
Old Mar 6, 2012 | 09:35 AM
austinlibke's Avatar
austinlibke
My 90' 5.0 had a similar issue, turns out the engine wiring was bad, before 1992, the spout and ignition module was on the dist. itself. once i changed that, she was good as could be.
Martin Torres
19
Jan 11, 2017 11:41 PM
cobrafromhale
59
Aug 17, 2016 04:52 PM
spreng37
Oct 25, 2014 02:28 PM
garbear17
1997 - 2003 F150
Jan 9, 2010 01:09 PM
thinkirish
1983 - 2012 Ranger & B-Series
May 9, 2004 02:15 AM
