'02 ranger rich fuel code
Old Jun 26, 2013 | 12:59 PM
hydro man 17's Avatar
hydro man 17
Just checked SES code and read P0162 I think. Stated rich fuel mixture bank 1 & bank 2 (3.0) Is this an O2 sensor or MAP issue?
Thanks
MIke
Old Jun 26, 2013 | 03:35 PM
daveya48187's Avatar
daveya48187
Go to P0162 02 Sensor Circuit Malfunction (Bank 2 Sensor 3) says P0162 is a Ox sensor circuit malfunction
Old Jun 27, 2013 | 06:38 AM
pawpaw's Avatar
pawpaw
You need to be certain of the code Number you posted, as it's for the bank 2 after cat O2 sensor, so that code Number doesn't match up with your posted Meaning of the number being for Both cyl banks running rich.
Old Jul 2, 2013 | 04:17 PM
hydro man 17
pawpaw
Thanks, finally got a chance to check again. Codes are now 0172 & 0175 bank 1 & 2 too rich. Is there any common device that would cause both O2 sensors to show a failed state?
Only thing that I can think of is that I put about 2 gal of "stale" gas with some sat-bil in it a couple of days before the code came up. Is this a possibility?
Thanks
Mike
Old Jul 2, 2013 | 05:25 PM
pawpaw's Avatar
pawpaw
The O2 sensors haven't failed, they're just reporting on the O2 level in the exhaust gas & they're saying there isn't enough O2 in there.
SO, the question is whats going on upstream of the O2 sensors that could cause that condition. Dirty MAF sensor, leaking fuel injectors, fuel pressure too high, faulty IAT sensor, or engine coolant temp sensor, clogged air filter, are some things that come to mind.
Are these the only trouble codes you have, if not post All code Numbers found, as they can offer up good trouble shooting clues.
Old Jul 2, 2013 | 07:49 PM
78Broncoinpieces's Avatar
78Broncoinpieces
does your truck have the flex fuel module?
when my 2000 began running rich, very rich, it was because the flex fuel module could no longer determine the correct amount of alcohol in the fuel. the higher the percentage of alcohol, the more fuel is needed for normal operation.
the f-f modules were eventually phased out, I'm not sure what year that was.
Perry
Old Jul 3, 2013 | 01:01 PM
hydro man 17
Thanks for the replies.
No it is not flex fuel but but I don't know what the Ethanol content is in the gas, Ca is not required to post it I have been told.
I had filled up with Cheveron gas before I cleared the codes. Took it for a short drive after fixing a wheel bearing issue and so far no new codes but oonly drove about 2-3 miles.
Air filter is clean spark plugs only have ~15-20K on them and engine basically runs great and I get about 21-22 MPG so I don't know what else.
Yes, those were the only two codes.
Old Jul 3, 2013 | 03:11 PM
pawpaw's Avatar
pawpaw
OK, good feedback on no other codes & the air filter & plugs being new.
Chevron is a "Top Tier" fuel & as such is to contain not less than 8% & no more than 10% ethanol. Chevron also has some Techron already blended in, so it might tidy things up some if you continue to use it. It has a good reputation for being a quality fuel, so feel comfortable using it to keep the fuel system, intake valves & piston crowns & combustion chamber tidy.
Not sure what effect the old fuel may of had on things, but if it was added with the tank about full, it would have been diluted a good bit & I don't see how it could cause a rich code for both banks.
If the codes haven't returned, don't worry about it, if they hang around, without any additional code clues, have a look at fuel pressure & if its holding pressure after the engine is shut down & let us know what you find.
If you have, or can come by a scantool that'll read computer live PID feeds from the vehicles engine sensors, have a look at short & long term fuel trim, O2 sensor switching speed & range, MAF sensor PID & let us know what you find.
Old Jul 3, 2013 | 03:38 PM
hydro man 17
Thanks,
And yes I have AE with Ford enhanced package for my '01 Powerstroke but I am pretty computer stupid so I will have to stumble through that. Getting the big truck and fifth wheel ready for a road trip this month so hopefully the Ranger will behave for now.
AnOldDog
Modular V8 (4.6L, 5.4L)
Apr 6, 2007 08:54 PM
84f250460
1997 - 2003 F150
Dec 2, 2006 10:10 PM
elrodalonzo
Apr 17, 2006 10:14 AM
1966Lincoln
Apr 23, 2005 12:35 PM
softball10
1997 - 2003 F150
Sep 26, 2002 06:06 PM
