WOOD FLATBED BUILD - 3D MODEL AND CONSTRUCTION PLANS
Old Jun 26, 2013 | 02:30 PM
Ken Blythen's Avatar
Ken Blythen
Ray - regarding the elevated fuel filler, you might need to be conscious of how full the tank & neck get.
Because the new filler will be a lot higher than the vent in the top of the tank, gas in the filler neck could cause flooding forward to the charcoal canister.
I think it's the older Chilton manual that gives a good description of the evap system for the tanks; there is an intentional cavity designed in the top of the tank that is supposed to stay full of air.
I just can't remember the details of why - maybe also to prevent flooding the charcoal canister.
The high neck is going to make fill-ups a pleasure!
Old Jun 26, 2013 | 02:32 PM
Gary Lewis's Avatar
Gary Lewis
Ken - I'd give you reps for that if I could. (Apparently I'm quite stingy with the things.) Good point!
Old Jun 26, 2013 | 02:39 PM
Ken Blythen
I'd hate to see the truck, & new deck, burn.
Old Jun 26, 2013 | 02:43 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Gary I went ahead and gave him reps for you sounded like good info for Rays flatbed build.
Trav
Old Jun 26, 2013 | 02:49 PM
Gary Lewis's Avatar
Gary Lewis
Trav
Reps to you for doing that. Thanks!
Old Jun 26, 2013 | 02:52 PM
Redneckfordf2502002
no problem gary I would rep you too but I can't LOL. Thanks for the reps.
Trav
Old Jun 26, 2013 | 03:09 PM
WADE MMT/PSD's Avatar
WADE MMT/PSD
Former Vendor
Sweet thread. Love the flip top box on the front!!
Old Jun 26, 2013 | 04:02 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I'm looking at the through view and as a carpenter I would suggest a vertical at each side of the toolbox (inside) that goes from just under the headache rack down to the bottom of the deck skirt.
This could be glued and screwed (or bolted) to both the side and the front crossbrace (joist)
Adding a lot of strength and support.
Joist hangers are fine for what they are, but they are likely to fail in tension and shear if you try to use them dynamically.
The truck (and bed) are going to flex constantly, unlike a house.
You're also going to have to seal the cross grain arch at the wheels.
This will dry out faster than the rest of the bed and check.
That split will travel down the length of the side.
I would suggest a saturating coat of marine epoxy.
Keep brushing it on to the end grain of the cut until it remains wet.
Once it hardens add another coat.
When it soaks into the end grain it fills the cells and binds the fibers together.
When it hardens in place there are no pores for water to soak into.
Old Jun 26, 2013 | 04:48 PM
RAY1986F150's Avatar
RAY1986F150
Gary and I have discussed the venting a little. He has two vent tubes I am going to get from him. This will allow me to run the vent tube further up to the new cap. I don't have any smog stuff attached to the truck anymore. So no worries about saturating the canister, its not even there. There is a vent in the very tippy top of the tank that has a small plastic hose barb for the line that goes to the canister. I currently have been running with this hose barb uncapped open to the atmosphere so that my tank doesn't implode from the pump pulling gas out of it. The stock filler neck is already higher than this point and I have had no issues with gasoline coming out of that vent. Solution: Run a gasoline grade rubber hose from that vent up to the same level as the filler neck or higher. That way if gas does come out at the barb, it has a long way to travel before it escapes the safety of the hose.
Old Jun 26, 2013 | 04:50 PM
RAY1986F150
Something like this?
whisler's Avatar
whisler
Awesome looking. I will be watching this as I had a similar project in mind but don't have your design abilities.
Old Jun 26, 2013 | 05:01 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Yes.
Even wider (2x6?) might be better from a standpoint of surface area and having the fasteners separated across the grain.
If you made it the full width you could eliminate the 'frame' inside, and wouldn't have to block it out below.
Notch the deck board around it and it will tie both the box to the deck frame and the front and side of the box, as well as the front and side of the deck together.
Side grain to side grain is a much stronger joint than butts.
Urethane construction cement like PL Premium in a caulk tube would set up so you couldn't get that apart with a sledgehammer.
Ray.
I'm envious of your CAD abilities.
Just an analog guy in a digital world I suppose...
My 2c
Old Jun 26, 2013 | 05:26 PM
  #28
Franklin2's Avatar
Franklin2
The plastic fitting on top of the fuel tank has a roll-over valve incorporated in it with a little metal ball inside. It's supposed to block the fuel from running out of the vent in case a accident occurs and the truck turns over.
Having said that, I am assuming it is a metal ball, and I guess in that case it's not going to float up and block the vent if you over fill it. If it is metal, it must be gravity operation only unless someone knows different.
Old Jun 26, 2013 | 05:58 PM
  #29
RAY1986F150
Yes.
Ray.
My 2c
Great IDEA!!! Tomorrow when i get back to work i will make it happen. And don't be envious of anything I have....envy is evil
Old Jun 26, 2013 | 05:59 PM
  #30
RAY1986F150
Thats good to know.
