Fault codes, chasing problems.
Old Jun 24, 2013 | 07:44 PM
PJ-Hunter's Avatar
PJ-Hunter
So blew a seal in the turbo. Rebuilt it.
Still running weird. Blowing more black smoke than blue now.
My brother ran a test on it twice and got two codes. I cannot remember the code # but I remember what they were.
1st was a cylinder 6 contribution fault code and the second was a cylinder 8 contribution fault code.
Can someone explain what these are and what possibly we can to do try and fix? Would it be bad injectors? My brother doesn't know much at all about Fords. He was a Dodge mechanic and hasn't worked on Ford Diesels.
Old Jun 24, 2013 | 08:11 PM
F350-6's Avatar
F350-6
Fault codes from a cylinder contribution test almost never mean anything, especially if it involves #8.
Running weird is a little hard to diagnose. Care to give us any more hints than smoke?
Old Jun 24, 2013 | 08:20 PM
PJ-Hunter's Avatar
PJ-Hunter
Takes a little to boost up. Runs like it is missing.
Motor is vibrating more than normal.
Old Jun 24, 2013 | 08:47 PM
F350-6's Avatar
F350-6
So, slow to build boost? Any problems with overall boost pressure?
Truck missing at idle? While normal driving? Under load? WOT?
Motor vibrating while you stare at it at idle? Can feel it at idle? While normal driving? Under load? WOT? How much more than normal? How much does it vibrate normally?
Next tell us about it's maintenance history, mods, and any other background info that might be useful.
Old Jun 24, 2013 | 09:06 PM
PJ-Hunter's Avatar
PJ-Hunter
Slow, then builds up fast.
Yes for all three.
Yes. Yes. Yes. Yes. Way more than normal. Feels like I have an unblanced tire but I know I don't.
I have a 4" exhaust. Bully Dog chip. New turbo seals and billet wheel from Riffraff. K&N air cleaner. New cam gear in 2009. New water pump a month ago. oil changes every 5000. Tranny fluid annually. Just installed new glow plugs and GP relay. Had to redo the injector seals 3 years ago. Other than that, just random little things
Old Jun 25, 2013 | 01:13 AM
cutlass's Avatar
cutlass
Here's a bump for ya!
Old Jun 25, 2013 | 05:39 AM
PJ-Hunter's Avatar
PJ-Hunter
Thank you.
Old Jun 25, 2013 | 06:11 AM
Tugly's Avatar
Tugly
...Blowing more black smoke than blue now.
  1. I suspect the collector guide pin never got lined up on the back of the turbo.
  2. Pull 42-pin connector (over the D-side valve cover) and ohm out all solenoids.
Old Jun 25, 2013 | 06:58 AM
PJ-Hunter's Avatar
PJ-Hunter
What are the P & D labels? And what ohm values should I be looking for?
Is that a way to test the injectors? My brother put his scanner on it and ran a test on them and they all passed the buzz test (what he called it) but he said that doesn't mean much. They could still be bad.
Old Jun 25, 2013 | 07:54 AM
Tugly's Avatar
Tugly
Passenger side voltage common (odd-numbered injectors) and Driver side. About 3 ohms each, but it's important they all match. This tests the solenoid coils and the connections to them from the 42-pin connector through the UVCHs.
Old Jun 25, 2013 | 08:08 AM
PJ-Hunter's Avatar
PJ-Hunter
So do those numbers any way correlate with the "buzz test" that the Snap On scanner does?
I will try to do a reading today when I get home.
Old Jun 25, 2013 | 08:35 AM
Tugly's Avatar
Tugly
The buzz test activates (buzzes) all solenoids at the same time at first, then it activates one at a time, in numbered sequence. This confirms the IDM is working, there is electrical connection to each solenoid, each solenoid coil pulls, and the solenoid plates lift/fall. It does not confirm (with certainty) the quality of the electrical connections, the coils, the solenoid plate is properly secured to the poppet valve, or that the clearance is accurate. Ohming out the 42-pin connector just assures all the electrical connections and coils are within spec... that's it. Fortunately, this is easy to test... and is a very common failure when things go-a-missin'.
Old Jun 25, 2013 | 04:18 PM
PJ-Hunter's Avatar
PJ-Hunter
So if they don't all ohm out close to identical, where would one go from there?
Old Jun 25, 2013 | 04:41 PM
01PS's Avatar
01PS
Are you asking because yours didn't ohm out correctly? Post your results. Could be bad injectors. Could be bad UVCH. Need more info!
Old Jun 25, 2013 | 07:01 PM
PJ-Hunter's Avatar
PJ-Hunter
I can't get my ohm tool to read any of them. But I know that if they were all 0, my truck wouldn't start or run.
