Looking for some part numbers
Old Jun 23, 2013 | 10:09 PM
npccpartsman's Avatar
npccpartsman
I'm making a list of odd gasket part numbers that I need to finish my motor and can't find or don't know if they exist.
1). Oil cooler assembly gasket where it bolts to the top of the motor.
2). D-ring where the HPOP connects to the branch tubes (04 motor). I don't think it comes in the HPOP seal kit.
3). White Teflon backup rings that go on the standpipes and dummy plugs. I'm not sure they're even available from Ford but I know they're available somewhere in the hydraulic world. They're pretty common.
4). O-rings for CPS and CKS sensors. The numbers I have are 3c3z9n963ha and ja for the CPS and 3c3z9c064da for the CKP but they don't show up on AutoNation or other dealer sites.
5). Gaskets for the water drain plugs in the side of the block
Any help (or donations) would be greatly appreciated.
Old Jun 23, 2013 | 10:17 PM
bismic's Avatar
bismic
3C3Z-9229-B should be a gasket kit for both the CMP and CKP. 3C3Z-9N693-JA and 3C3Z-9N693-HA were superceded w/ the kit number.
Old Jun 23, 2013 | 10:20 PM
bismic's Avatar
bismic
This is what I have for the block drains:
O-ring: 1/8 inch thick and 5/8 inch inside diameter
or O-Ring from oil drain plug part # 3C3Z-6026-DA
Old Jun 23, 2013 | 10:26 PM
npccpartsman
Nice--thanks Mark. I'll update and add to my parts list.
Old Jun 23, 2013 | 10:31 PM
bismic's Avatar
bismic
Not sure if the dummy plug o-rings / teflon washers are available. See thread below (specifically post #5):
Oil Rail Plug and Stand Pipe O-rings - TheDieselGarage.com
Old Jun 23, 2013 | 10:42 PM
npccpartsman
Not sure if the dummy plug o-rings are available. See thread below (specifically post #5):
I kind of thought as much. I'm just going to buy the dummy plugs and replace them. The standpipes will come with the heads and/or head gasket kits. I really need to do the wave rail nipples while I have them out too. What the heck.....it's only money, right??
Old Jul 2, 2013 | 08:16 AM
npccpartsman
I found a set of 16 NEW Sealed Power valve lifters on Ebay for $92 shipped to the house. That's considerably cheaper than I found them ANYWHERE without shipping.
SRSherrill75
Jan 27, 2016 04:01 AM
lotech
May 25, 2014 09:46 PM
slorider
Apr 15, 2012 04:32 PM
dieselaholic
Nov 23, 2011 08:02 AM
mblanken881
Jan 11, 2009 09:45 PM
