vacum hose question
Old Jun 23, 2013 | 06:37 AM
luv2ski's Avatar
luv2ski
vacum hose question
My 390 distributor has 2 connections.The front one is going to carb "front as is closest to radiator.Second on is going no where the is no nipple to be found.
Truck seems ok except for a backfire issue on hot days,runs fine ,idles fine,starts fine.
do i have correct distributor ?
Old Jun 23, 2013 | 06:34 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Dizzy ID number is located on a tag (probably missing) and stamped on the base. Post what it is.
Old Jun 23, 2013 | 06:40 PM
2500ak's Avatar
2500ak
I don't quite understand what you mean here. Do you mean there is a vac line coming off the dist that doesn't connect to anything?
Old Jun 23, 2013 | 06:42 PM
NumberDummy
I know what the OP is speaking about inre to two connections, that's why I asked for the dizzy ID number.
Old Jun 23, 2013 | 06:50 PM
2500ak's Avatar
2500ak
Here's an old picture of what the dist on my FE looks like I'd get a better one but I keep that truck at my grandma's for when I fly up to visit her now.
Can't say if it's the original dist though.
Old Jun 23, 2013 | 07:08 PM
NumberDummy
Introduced in 1971 F100/350 (1967 cars), 12A091 Type 2 vacuum control valve installed. Some people removed the vacuum hoses, capped off the nipples they connected to.
Old Jun 23, 2013 | 07:25 PM
montana_highboy's Avatar
montana_highboy
Those were smog era dizzys, they had both advance and retard canisters....they were "retarded" to say the least (no pun intended)....
Ditch it and get a single can dizzy.
69-er
May 3, 2017 08:30 AM
1972-34ton
Jul 6, 2015 07:29 PM
dylansf23
Nov 24, 2013 07:13 AM
89lilfoot
Oct 31, 2011 11:25 PM
saauvenshine
Mar 13, 2008 04:36 PM
