Quick Question - What fuel pressure?
Old Jun 21, 2013 | 01:57 PM
brwolfjr's Avatar
brwolfjr
What fuel pressure do I want to be running.
I just installed a driven diesel regulated fuel system with bowl delete.
I am not sure what pressure I want it set at when the truck is at idle.
I do not have the ability to check at WOT yet.
Thanks
Ben
Old Jun 21, 2013 | 02:08 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Try it at 55-60 psi and see how it runs.
Old Jun 21, 2013 | 03:13 PM
Tugly's Avatar
Tugly
Stock is about 50-55 PSI. You don't want to jack up the pressure (like over 60-65) in search of better performance... nothing to see here, folks.
Old Jun 21, 2013 | 03:31 PM
honeydew's Avatar
honeydew
You now have the luxury of easily testing different pressure settings. I did that and the truck seems happiest at 63 psi so that is where it has been set for a while. Your results may vary.
Old Jun 21, 2013 | 03:44 PM
Robert6401's Avatar
Robert6401
Idle is irrelevant unless it really high or really low. If you can get it to hold between 50-60psi at WOT, then you are where you need to be.
Old Jun 21, 2013 | 04:12 PM
brwolfjr's Avatar
brwolfjr
Thanks for the answers. It looks like I have to do more gauges sooner then rather then later.
Old Jun 21, 2013 | 04:58 PM
snknby123's Avatar
snknby123
My .02... I have a 01 F250. I jacked it up (via fuel return springs) to about 65psi but noticed longer crank times. Dropped it back down to stock (about 55psi) and it fires noticeably quicker. Not really sure why the added pressure would cause longer crank times. Anybody?
Old Jun 21, 2013 | 05:12 PM
Tugly's Avatar
Tugly
I'm going through scenarios in my head and the only thing I can come up with is either you "reset" something when you changed it, or cavitation issues. Hutch mod?
Old Jun 21, 2013 | 05:43 PM
snknby123's Avatar
snknby123
No, not cavitation!
That word, cavitation! Man it just ranks right up there with venereal disease for us PS guy's . Where and how could cavitation play a roll here do you think?
I will add that when I was changing fuel pressure back to 50-55psi I was draining the fuel bowl a little and noticed the fuel was Red. Come to find out I put 20gallons of Red Dye Diesel from Southern States. I pumped the fuel from the same pump everyone else was pumping from. A guy in a F350 was in front of me.
No Hutch Mod yet. I checked my fuel pressure and it's good at idle (55psi) and WOT.
Old Jun 21, 2013 | 07:05 PM
brwolfjr's Avatar
brwolfjr
Why would you think cavitation on slow starts?
Old Jun 21, 2013 | 11:26 PM
Tugly's Avatar
Tugly
I'm stretching to answer the question "Why slower starts with more fuel pressure?" I do know one thing: Fuel doesn't compress, but air does. If the fuel pump were to introduce air, you lose a little fuel flow. More importantly... air in the injector compresses when the oil hits the top side of the plunger. The "give" from that compression has oil chasing the plunger down... diminishing your ICP, as well as reducing the quantity of fuel delivered. If you ever want to get a pump to cavitate... increase the backpressure past a certain threshold. I'm not guessing on that one piece of physics.
Old Jun 22, 2013 | 12:03 AM
Shake-N-Bake
There is no possible way that I can think of to relate fuel pressure to crank time. I presume you stop cranking as soon as the injectors fire so that is going to happen at the same moment no matter what the fuel pressure is. Even a few psi of fuel in the heads will be enough to fire the engine.
Keith Wells
Oct 5, 2020 03:21 PM
crop harvester
Feb 28, 2016 02:24 PM
topscrt
Modular V10 (6.8l)
Sep 19, 2011 11:47 AM
wildstang
May 1, 2009 02:32 PM
Mr. Bob
May 4, 2007 01:24 PM
