correct fuel pressure
Old May 1, 2009 | 11:56 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
I tried the search but either I am an idiot or it just doesn't work that good, I only saw one reference to the pressure. I used fuel pressure as the search words.
Anyways, the one reference I found said 70psi. Is the the target or is there a range, what is too high of a pressure? I just checked mine and it bounces between 50-60psi, but I also was not able to get it to stop leaking past the connection so I am probably loosing some pressure there. Should it be bouncing 10 psi and when you check the pressure, is it at idle?
Thanks for any help.
Old May 1, 2009 | 12:48 PM
Hussler's Avatar
Hussler
50-60 PSI at idle is good.
Yes it bounces as the pump works off the cam.
Old May 1, 2009 | 12:54 PM
gt8684's Avatar
gt8684
well as far as pressure goes, im pretty sure the max is 80-85, you dont want to go higher than that. i think most people on here try and settle somewhere between 70-80..is your truck a cali truck, or fed truck? you might want to consider changeing the fuel lines in the valley, might help with pressure loss
Old May 1, 2009 | 01:35 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Thanks Hussler, I guess I don't need to do the fpr shim yet.
gt8684, how can I tell? I live in Vermont and bought the truck used last summer from a used car dealer in Mass.
Old May 1, 2009 | 02:32 PM
gt8684's Avatar
gt8684
if i recall correctly (hoepfully someone can help me) fed trucks had a GPR, and cali trucks had a different computer unit that controlled GPs?.... and the cali model also have a black disk attatched to the fuel pump and is kinda under the turbo... here is a diagram of the pics below, thanks to tjbegg whom i barrowed them from!
california model
fed model
BennyLumpkin
Jul 9, 2013 07:31 PM
RIKIL
18
Nov 20, 2011 04:47 PM
Ford Runner
Sep 27, 2010 09:16 PM
ms1780
Jun 22, 2009 04:36 PM
JR270
Mar 21, 2006 08:21 AM
